Haze at idle?
Old Dec 13, 2011 | 11:26 PM
fjkfta's Avatar
Haze at idle?
I have an 05 2500 4x4 swb At idle it has a haze you can smell the fuel in it (burns eyes). I changed fuel filter no change. My guess is injector failure so i was wondering if i unplug each injector one at a time to watch when haze stops could i tell wich injector is bad? Low on cash from xmas so only want to replace one right now and dont want to take it to a shop if i could diagnos and fix myself. Thanks in advance for the help
Old Dec 14, 2011 | 12:12 AM
BigIron70's Avatar
Cummins Guru
You will have to cap injector line at the rail using special capping tool one at a time. Or run a injector contribution test if you have access to scanner or dealership buddy that can run test for you. Usually the lowest reading % injector is the culprit. Good Luck
Old Dec 17, 2011 | 01:59 AM
fjkfta's Avatar
how much would a contribution test cost me at the dealer (ballpark) Sorry took so long to respond was out of town working.
Old Dec 17, 2011 | 04:42 PM
jhenson's Avatar
My'03 did the same thing while I was hotshotting. At idle you'd thought I had 200hp injectors the haze was so bad. No dealership could figure it out. Talked to the guys at Dynamite Diesel and they seemed to think that a pintle in one or more of the stix was sticking open and leaking fuel by.
I have run Power Service in every tank since the truck was new which did make it run better in my opinion but for some strange reason once I quit working the truck the problem went away. Now with 300k on it I do get a strange idle from time to time until I do work the engine hard and then it idles like a champ but I still have no haze until I romp on it .
I'd start by trying some fuel treatment and go from there.
Old Dec 18, 2011 | 07:02 PM
BigIron70's Avatar
Cummins Guru
Usually check out is one hour labor time to do a quick scan for codes and injector % of contribution test, injector kill test. CP3 test and injector return flow test, limiting valve test, lift pump test is usually extra labor charge.
dodgediesel
Jan 4, 2008 09:14 PM
aksparkey01
Nov 27, 2007 09:59 PM
48snowman48
Oct 16, 2007 05:17 PM
C'ya
May 22, 2007 08:37 AM
B.A.Ram
May 1, 2007 07:53 PM
