smokey haze at idle
Old Oct 14, 2007 | 09:51 PM
48snowman48's Avatar
smokey haze at idle
Hey all, new to the site.
I recently bought my second Dodge diesel and am so far very satisfied with the truck. I have noticed that the truck will smoke from the exhaust when it idles. It smells and looks like raw fuel. It will smoke like this anytime the truck sits for more than about 30 seconds or so, not matter how warm or cold the engine is. The truck has 297,000 miles, and other that the mods listed below, should be stock. The head was off of it at a qualified shop not all that long ago after the gasket blew, so I am going to assume that it is not a blown gasket again. My mileage has been hanging around 20 mpg and the truck runs very well. So this problem is nothing more than a nuisance to me. Any ideas? Thanks in advance.
John
Old Oct 14, 2007 | 11:05 PM
Brendan's Avatar
Has it been timed? Timing in the injection pump can slip causing some different issues, one being some haze at idle.
Old Oct 15, 2007 | 01:49 PM
The timing was advanced, then taken back to stock or close to stock before I got the truck. My old 97 was advanced to 16* and I saw no smoke except during cold start. I would assume that this one is back to around 12.5*. Do you think it might have retarded back a little further than that?
Old Oct 15, 2007 | 05:03 PM
dieselman2300's Avatar
Are you sure it doesnt have upgraded/aftermarket injectors?
If it doesnt, I would re-check your timing. It can slip pretty easily if the pump shaft wasnt cleaned properly.
Old Oct 15, 2007 | 08:10 PM
I am almost positive that they are the stock 215s. The truck runs good, but not good enough to have huge injectors in it. Plus, I have never seen one smoke like this one does after it gets warm.
Old Oct 15, 2007 | 08:21 PM
Check the timing then. It probably slipped.
Old Oct 16, 2007 | 09:45 AM
berner's Avatar
Check your fuel pressure. The Overflow valve might be worn out. Cheap, easy fix.
Old Oct 16, 2007 | 01:11 PM
overflow valve is in the lift pump? Isn't the ticking noise I hear the lift pump?
Old Oct 16, 2007 | 05:17 PM
Nevermind, don't know what I was thinking. Overflow valve is in the front of the injection pump.
kurtswater
13
Apr 14, 2008 12:57 PM
dodgediesel
Jan 4, 2008 09:14 PM
aksparkey01
Nov 27, 2007 09:59 PM
C'ya
May 22, 2007 08:37 AM
B.A.Ram
May 1, 2007 07:53 PM
