Having some shaking issues.
Old Feb 19, 2011 | 04:52 PM
lu798welder's Avatar
When I'm at a dead stop and take off there is a little shaking going on somewhere. This is while i'm accelerating not while i'm letting the clutch out. When I'm in 4 wheel drive it doesn't seem to do it as bad but I was in snow so it may not matter. Seems to quit by the time i hit third gear. Any ideas?
Old Feb 20, 2011 | 10:10 AM
jhenson's Avatar
If you have a 2-piece rear shaft the carrier bearing could be suspect. The rubber fell apart on mine and caused the shaft to run out-of-round, so to speak, upon take-off. Once up to speed it smoothed out. Got me a Spicer carrier bearing (WAY BETTER DESIGN) FOR $60 and no more shudder.
Old Feb 20, 2011 | 12:09 PM
Nascarcamper's Avatar
Do you happen to have the part number for the Spicer bearing?
Thanks in advance.
Old Feb 20, 2011 | 06:23 PM
jhenson's Avatar
I've slept since I put it in but I'll try to find that number for ya.
Old Feb 21, 2011 | 02:09 PM
jhenson's Avatar
Hey Nascarcamper, found that part number for ya....it's Spicer #210391-1x
Did mine myself but next time I'll just pay the driveline shop I got it from the extra 20 bucks to do it. Oh well, gained some extra experience for myself I guess. Hope this helps you out.
Old Feb 21, 2011 | 06:49 PM
Thanks jhenson I'll give that a shot hopefully that'll fix it thats alot cheaper than what i was suspecting was causing it.
Old Feb 22, 2011 | 01:02 AM
jhenson's Avatar
The Spicer design is more along the lines of what you'd see under a medium/heavy duty truck. You know, the round design. That oddball setup that these trucks come with is just awful. You're depending basically on four rubber tabs to hold the bearing on center. Crawl under your truck and grab your driveshaft right at the bearing area see how much up/down movement you've got. You'll be surprised at what you find. With the Spicer bearing on there you have ZERO MOVEMENT!!!
Old Feb 22, 2011 | 07:42 AM
Thanks jhenson!!
Old Feb 22, 2011 | 02:15 PM
jhenson's Avatar
Keep us posted on what you find.
nrussell
Jul 29, 2009 08:33 PM
12ValverDave
Sep 16, 2007 03:42 PM
mike_ward
Sep 11, 2007 02:08 PM
RedRacer44
May 3, 2007 10:37 AM
dieselfuelonly
Jan 28, 2007 09:55 AM
