Has my truck been Smarty'd?
Old May 1, 2008 | 02:06 AM
Remnik's Avatar
Since I bought my truck used, how would I know if it had been loaded with a programmer like a Smarty? The way I understand it, the software is just loaded into the ecm and is undetectable right?
The reason I ask is that my truck smokes way more than I thought a newer truck should when I'm on it a little. It puts out a pretty good cloud if I give it half throttle. It definitely smokes more than any of the previous cummins trucks I've had except for maybe my first '93 with a maxed out pump.
The truck doesn't feel rediculously powerful but definitely healthy. I'm gonna check for codes in the morning and maybe I'll have a look at the turbo. I'm a little worried that it won't pass emissions, I gotta have that done next week to get plates.
Old May 1, 2008 | 10:30 AM
TonyB's Avatar
One way to tell: put it on a dyno & see how much HP & torque.
Judging by your smoke comment, I suspect that you may not have a power adder, but just bigger injector nozzles.
It could also be that you have a boost leak - not enough air to go with the commanded fuel.
Tony
Old May 1, 2008 | 01:19 PM
Remnik's Avatar
I checked the codes today and got p0514. Did a search, found out it's a battery temp sensor code, no big deal.
I'll look at the turbo and check for boost leaks this weekend.
Today I floored it for the first time since I got it (yeah, I know but I've been trying to get good mileage). Man, this thing really moves for a big ole dually
I don't know if it's stock or not but I'm impressed.
I'm hoping that when I get the emissions done they'll be able to tell me the hp/tq numbers.
Old May 1, 2008 | 01:50 PM
scottsjeeprolet's Avatar
You gotta do emissions in CO on a diesel? WOW!
Check you air filter & intercooler boots for leaks.
Old May 1, 2008 | 04:00 PM
TonyB's Avatar
Not unless Co is different than AZ & Ca. They only put a load on the chassis (motor) and check for emissions. The numbers may be there, but they don't publish or release.
Tony
DmaxEter
43
Aug 28, 2012 07:45 AM
CoolumConst
Oct 13, 2008 11:20 AM
Buffman88
Apr 26, 2008 06:42 PM
Diesel_Storm
Aug 26, 2007 05:08 PM
txs
Sep 30, 2005 10:32 AM
