Grid heater stock amperage.
Old Dec 14, 2017 | 10:50 AM
gw ellis's Avatar
Does anyone know how many amps a healthy grid heater should be pulling?
My problem is that when my grid heater activates my truck kicks out a 2149 and runs on 3 cylinders for 10 seconds. You can read about everything I have changed out on the post P 2149. Thank You, Grant.
Old Dec 14, 2017 | 08:07 PM
BarryG's Avatar
Cant say for sure on an 07 but my 01 service manual for the 01 is 90 amps per grid for a total of 180 amps between the two of them.
Old Dec 14, 2017 | 11:10 PM
gcssr's Avatar
So a 180 amp draw on a 135 amp alternator will show a negative charge, as it cycles again shows a positive charge at around 14+ volts;;
Old Dec 15, 2017 | 08:47 AM
BarryG's Avatar
And that with the alternator at idle so no way it is putting out 136 amps though even high idle didn't make a noticeable difference. The two batteries aren't there for nothing strictly for the grids no other reason for them. On the 01 it was max 30 seconds wait to start for the grids then they could cycle for a max of 180 seconds or you reach a speed of 22 or 23mph.
90firstgen
Dec 14, 2007 12:49 AM
MMarty
Nov 15, 2007 08:55 AM
ChrisM55
Nov 4, 2006 01:09 AM
rjm022
Oct 12, 2005 07:13 AM
Kruchr
Jan 6, 2004 12:46 AM
