Grid heater light on while driving today...and a dinging sound.
Old Jun 10, 2012 | 12:28 PM
06RAM2500's Avatar
Mine done the same thing a week and half ago. Only thing was, I forgot to tighten an injector line at the rail. Thinking that was the cause of it......
Old Jun 10, 2012 | 01:36 PM
banyon's Avatar
When my truck did this it was two bad injectors. One dealer had me put on a new lift pump, a fca valve, etc. I ended up pulling the injectors & having them tested. Two were bad. I've been driving about six months & the light is off. If you try everything else pull them, it's not a hard job.
Old Oct 21, 2014 | 11:23 AM
jbritvar's Avatar
I have had this problem for awhile (over 2 years). That being said, I have posted and read numerous posts on the subject but have failed to find a solution. I, like STate live in colorado and experience this issue on eisenhower and decending into denver. I found that it only happens when I let off the accelerator going down those hills, but if I stay on the pedal it dont come on.
This issue did not start happening until after I bought the truck in salt lake and the motor blew a month later. I had the motor rebuilt, and was forced to replace the whole fuel system (bad injectors). I know its not my injectors, and the dealer says I have the most recent software. If anyone solved this problem please let me know.
Old Oct 21, 2014 | 01:50 PM
gcssr's Avatar
What temp thermostat u using, could be to low allowing engine to rum to cool when letting up on accl. pedal, u should have a 190 degree, it sound like cooling or over cooling unless u are in the pedal.
Old Jan 7, 2016 | 05:49 PM
ColinP's Avatar
My WTS light was coming on, and I would have a P1223 code show up. I would hear 10 dings. Sometimes I would have a CEL with a fuel rail code (I forget the number)
Anyway, I fixed the problem, it turned out one of my injector tubes (#6) needed to be retorqued. Apparently it had somehow loosened up and was leaking.
Chessbay
May 7, 2013 03:07 PM
Dempsey 55
Nov 17, 2010 11:57 AM
Ramrod90
Feb 3, 2009 07:39 AM
Desert Diesel
23
Jan 4, 2007 01:49 PM
Tackdriver
Mar 31, 2003 11:06 PM
