Got a clue on the rough idle at startup!!!
Old May 8, 2007 | 04:25 AM
Dodgezilla's Avatar
I want lots of things! I NEED a clutch already at 12,000 miles but don't feel like shelling out that kind of money when the truck is still almost new! These new trucks are so touchy when it comes to BOMBing!
Stock isn't so bad. This truck stock makes about the same power as my old SO did with the EZ on it, almost..
Well, there may be a hole in my theory though. Sunday I was doing a bunch of running around and three more times during the day when I turned the key on the FP stayed up around 10psi and did not drop back down to zero. The truck started properly each time. I'm pretty lucky in that mine has only had a very minor rough idle twice with the blue smoke but it cleared up almost immediately.
Old May 8, 2007 | 05:38 AM
coolslice's Avatar
Originally Posted by Dieselhed
^^^^^ I would respectfuly disagree with that. After starting my 04.5 with a stock lift pump for 2 years wondering if today was the day it was going to give out. I put on the GDP Walbro kit and the speculation went away. Yes, I know that no electric pump (or any for that matter) is guaranteed not to fail, but piece of mind and constant 18 psi make me feel tons better. And for me, that's priceless.
I lost my LP @ 30k so I have the in-take version now. I would have that Walbro system without a doubt if I didn't have the in tank pump. The website says you can only use the Walbro with the filter mounted LP, correct?
Is the FASS the same way?
I have 2 problems with my truck that I'd like to improve. 1) the smokey startups with low FP. 2). My truck hesitates during acceleration when it shifts gears unless you are giving it a pretty good amount of fuel via the go pedal. Like the other poster said, these things are touchy about mods. I have a TST PMCR in my garage that I finally decided to remove because my truck was throwing codes and going into limp mode. I didn't trust it. I like what I read about the Smarty but I don't know enough about it. I assume it adds pressure, which isn't really good for the injectors on these HPCR engines from what I've read. Decisions decisions.... I must admit, I feel much more secure now that I'm back to stock.
t-boe
89
Jul 16, 2009 07:51 AM
JThiessen
Jul 29, 2008 04:27 PM
skipperw
Jan 16, 2007 02:39 AM
JIMCTD
Nov 5, 2006 03:14 PM
big red psd cc
14
Sep 1, 2004 01:39 PM
