Getting ready to roll 50,000!!
Old May 18, 2007 | 10:28 AM
COLEMAN1001's Avatar
Hey guys should I follow the standard maintenance out of the manual or is there any other changes/mods I should tackle when my 04 3500 rolls 50,000 miles. Thanks
I drag this around on a weekly basis...
Old May 18, 2007 | 11:59 AM
Nate-03 D's Avatar
If your trouble free so far you should be fine. If you haven't already check and change the diff fluids, tranny fluid ect. Make sure to grease everything up under the truck. Mabe even do a balance and rotate if need be, add fuel and drive.
Old May 18, 2007 | 03:52 PM
WhoozYaDaddy's Avatar
ensure you are servicing the transmission and rear differential.
Old May 18, 2007 | 08:16 PM
ataboy9026's Avatar
While that is good advice for the truck....... please be sure to remember you have to stop this thing somehow and your trucks brakes will have a workout doing it. Hopefully you have hydraulic disc brakes on the trailer, if you don't you'll wish you did with that weight. Electric brakes won't cut it with that weight. Some others may tell you otherwise but try to stop suddenly sometime and you'll learn quick. We all know our Dodge's have awesome pulling power but to stop a load like that will take some good trailer brakes. So keep that in mind so you don't end up IN my truck bed if I am in front of you!
Old May 18, 2007 | 08:33 PM
scoggins's Avatar
Had mine sence first week in October '06 turned 25,000 over today and the vast ma have had one of the trailers in my signature. not too goo for the fuel milage
Old May 18, 2007 | 08:40 PM
scoggins's Avatar
nice 4horse Sundowner
you Rodeo or show horses?
we show Arabs or as I like to call the "Opec-Warmbloods"
Old May 21, 2007 | 01:54 PM
Rodeo (always wanted to use this one )
We (my better half and I) Rope USTRC mainly.
X2 Arabs
Old May 21, 2007 | 09:03 PM
scoggins's Avatar
X2 Arabs[/QUOTE]
Old May 22, 2007 | 02:20 PM
Ok doing a rear diff service in the next day ir so....do I need a additive for the limited slip like my 2000 I had? And is Mystic semi synthetic 85w140 good?
Old May 23, 2007 | 01:39 AM
TexasCTD's Avatar
No Additive in AAM axles in 3rd gens. Dana Axles needed it....AAM does not.
Make sure the gear oil is Synthetic GL-5 rated. If so, it should be fine.
Old May 23, 2007 | 09:43 AM
Floridacracker's Avatar
make sure u change the sparkplugs, coils, cap, rotor, wires
just change the fuel filter., oil, trany filter (only because u tow) have ur ball joints checked and aliment
i have an 04.5 and just rolled 100,000 2 weeks ago and it runs better than new
Old May 23, 2007 | 09:20 PM
scoggins's Avatar
Yeah, don't forget the blinker fluid too!
Coleman---
Rope UP!!! & Good Luck!
Old May 24, 2007 | 10:00 AM
I attempted to change all these above but could not find a metric cresent wrench locally
Old May 24, 2007 | 10:05 AM
Coleman---
Thanks .....
j_martin
Aug 25, 2012 01:54 AM
ROCKNRAM
Dec 3, 2007 02:19 PM
Commatoze
Aug 19, 2004 04:00 PM
spots
May 28, 2003 10:44 PM
Shovelhead
Jan 6, 2003 02:31 PM
