Gearing Question
Old Feb 17, 2009 | 06:45 PM
Farmboy89's Avatar
Gearing Question
I recently bought an 05 cc sb 6 speed and was wondering what gears i had. I had an 01 with the 5 spd and this truck seems to have a LOT more low end torque. I was thinking i might have 4.10's but i get 20+ mpgs so i dont think thats possible. At 65 mph in 6th gear i am just under 2 grand rpm. Do i have 4.10's or the standard 3.73's?
Old Feb 17, 2009 | 07:42 PM
johndeere01's Avatar
i think it tells on the glove box door somewhere, hope this helps
Old Feb 17, 2009 | 07:53 PM
billie's Avatar
Assuming stock tires, 3.73.
Cya
Old Feb 17, 2009 | 07:55 PM
ratsun's Avatar
Cya
X2
Stock tires and 4.10s I am 2000rpm @ 60mph
Old Feb 17, 2009 | 08:08 PM
92'1stGen's Avatar
Just based off of what you have said, it sounds like you have the Getrag G56 transmission. In the 05's, there were two manual 6 speed transmissions offered, the NV5600 and the later G56. The G56 is geared a lot lower than the NV5600 was & is similar to the autos with a 4.10 ratio in terms of highway RPM's. Also the NV5600 was the last manual trans to be offered with a 4.10 ratio. 3.73's are the only thing available with a G56, but with the way it runs the RPM's, there is no need for any lower of a ratio.
In late, late 06 Dodge/Getrag introduced an updated G56 that had a higher 6th gear ratio, .73 I believe. Not a huge difference, but it helped get the RPM's down a little on newer trucks.
Old Feb 17, 2009 | 08:17 PM
Farmboy89's Avatar
but in the G56 wasnt reverse in a different place......Mine is all the way to the right and up just like dads 01????
Old Feb 17, 2009 | 08:26 PM
billie's Avatar
to the right and up should be the NV......mine is.
Old Feb 17, 2009 | 08:57 PM
Farmboy89's Avatar
thanks for the feedback.......guess im just not used to the 6 speed
Old Feb 17, 2009 | 09:11 PM
rich's Avatar
g56 is above 2k at 65 with 3 73
PRG
Jul 25, 2008 11:21 AM
2FEATHERS
Apr 30, 2008 07:27 AM
firepiper
Feb 9, 2007 06:41 AM
dtycoon2003
Sep 29, 2006 10:17 PM
malibu
Feb 18, 2003 07:21 AM
