G56 vs the NV5600
Old Sep 28, 2007 | 10:06 PM
Buckshotmckee's Avatar
Question G56 vs the NV5600
We got a new technician at work and tonight I got on the freeway behind him. He has a 04.5 with NV. I stayed right on him and pushed. We hit 95 real quick, and I know 95 is redline on my 06. He kept walking away from me. Now, I don't think 3.55s were and option in 04.5 so that rules that out. My only guess is that the NV is longer legged in 6th. Is this correct? Both trucks are pretty much stock, tires as well.
Old Sep 28, 2007 | 10:26 PM
DiEseLjunKy's Avatar
I think the NV's are geared a little higher than ours but I don't know what the specific ratio is. Surely someone that does will chime in. I do know that your '06 and my '07 is a .79 ratio in 6th while the newer '7.5 and '08 have a .76 ratio.
Old Sep 28, 2007 | 11:04 PM
53 willys's Avatar
I found this after a quick google
NV5600 Gear Ratios:
RANGE RATIO
1ST 5.63
2ND 3.38
3RD 2.04
4TH 1.39
5TH 1.00
6TH 0.73
REVERSE 5.63
Early G56 Gear Ratios:
1st 6.29
2nd 3.48
3rd 2.10
4th 1.38
5th 1.00
6th 0.79
Reverse 5.74
Old Sep 28, 2007 | 11:07 PM
53 willys's Avatar
I still wounder if a guy can buy just the 6th gear from a 07.5 truck to swap with my 06???
Old Sep 28, 2007 | 11:13 PM
NV5600 Gear Ratios:
RANGE RATIO
1ST 5.63
2ND 3.38
3RD 2.04
4TH 1.39
5TH 1.00
6TH 0.73
REVERSE 5.63
1st 6.29
2nd 3.48
3rd 2.10
4th 1.38
5th 1.00
6th 0.79
Reverse 5.74
Thanks! I just found the same info. It appears to be an 8% difference between the 2. That's why he kept walking away!
Old Sep 29, 2007 | 07:49 AM
MikeyB's Avatar
Yep, I have no problem bouncing off the speed limiter at 108mph.
MikeyB
Old Sep 29, 2007 | 03:00 PM
'strokeThis_'07's Avatar
My 03 will hit 108 as well...
Old Sep 29, 2007 | 04:12 PM
rip 112's Avatar
As will my 04. Great stuff!!!
Old Sep 29, 2007 | 05:57 PM
w.tx iceman's Avatar
You did use a professional driver on a closed course
Old Sep 29, 2007 | 06:34 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
Nah just rolled back the clock to the days when texas still had the safe and sane speed limit
Or Montana, Kansas ect with the Safe and Prudent
Old Sep 29, 2007 | 08:35 PM
MikeyB's Avatar
Naw, it's only 28mph over the limit on I-10 in West Texas.....
MikeyB
Old Jan 8, 2008 | 11:07 PM
PsychoRallye's Avatar
What RPM is the NV5600 (with 4.10s) at when you're at max speed. I think I was at ~3000 rpm when I was at 80 mph... which was very briefly! What RPM is redline with the **** thing? I felt like the engine was about to blow up at 3000 RPM !
I don't really have an occasion to go 108MPH anyway... but what is RPM in the lower gears (redline) ?
Old Jan 8, 2008 | 11:35 PM
rip 112's Avatar
I believe 3200 stock or close. 4.10s are gonna wind out quick, but pull hard. Many of us that hit 108 have 3.73s. I have hit 112mph with my 3.73s.
Old Jan 8, 2008 | 11:40 PM
Timmer's Avatar
how have i hit 115 in my truck then? i have a whitness and its not Kentucky windage eather
Old Jan 8, 2008 | 11:44 PM
rip 112's Avatar
speedo was probably off at the end...I got my mph reading from my navigation, which is wired directly into the speedsensor.
