G56 shift questions
Old May 19, 2009 | 09:09 PM
  #31
RiverRat2's Avatar
Originally Posted by D-Roc
As far as the almuinum housing issue being a reason for not running a "heavier" fluid, that doesn't make much sense.
Atf+4 had a heck of a lot more metal on the plug!
Yeah I mis quoted what he said,,, Cause I Asked again and He basically said the same thing about the tighter tolerances inside, and regular gear oil would be too thick, and wont lube everything enough,,,,
My Bad,,,,
I did change the fluids in everything and I agree I did not like the amount of metal on the tranny drain plug magnet,,,with ATF 4,,, Also I think that was the first time service for the tranny & transfercase,,,, the diffs were were in good shape and appeared to have been serviced twice, no sharp edges on the gears
Mines past warranty as well so, I Picked up a case of the RP gear oil @ the races for 96.00 out the door, that's about 12.00 cheaper per quart than the Mopar Gear lube!!!!!! I wont buy that again!!!!!! I Will!!!!! give the syncromax a shot when I find some,,,
Dave7060
0
Feb 13, 2012 05:03 PM
64camo
21
May 9, 2007 01:06 PM
jrogers
Apr 22, 2006 09:10 PM
motrapper
Dec 19, 2005 06:27 AM
