G56 shift questions
Old May 11, 2009 | 08:49 AM
mcolectd's Avatar
Mine always seems to shift smooth.
Old May 11, 2009 | 09:15 AM
chadder1313's Avatar
I dont like the way my G56 shifts either. Its always felt a bit on the tight side. Ive never had a problem downshifting though.
Old May 11, 2009 | 04:29 PM
D-Roc's Avatar
I have found Royal Purple Synchromax to be the best fluid from my experience, in my own truck. I'm out of warranty on the trany, so fluid choice is no big deal.
Even then, my first couple of shifts into third on cool mornings require a bit of finesse with my shifting and then its fine, shifting like a sports car...
Old May 11, 2009 | 08:11 PM
RiverRat2's Avatar
Originally Posted by rich
ATF4 and at about every 35k to 45 k if you tow like i do. already had one start to go bad at 10k lasted to about 52k
Are you running the Mopar ATF+4 fluid or something else?????
Old May 12, 2009 | 08:53 PM
rich's Avatar
the one that went bad was using factory fluid . i just use atf 4 from my carquest parts house
Old May 12, 2009 | 10:33 PM
RiverRat2's Avatar
so you have a manual and run the synchro max????
Old May 13, 2009 | 06:44 AM
D-Roc's Avatar
Yes. That is correct.
Old May 13, 2009 | 05:39 PM
JLee's Avatar
my 04 is a pain in the neck to get into 2nd when its hot (Las Vegas at 104) and just as bad to get into fourth when its cold -0 i use ams oil and change it every 30k
Old May 13, 2009 | 06:00 PM
tool's Avatar
I love the way mine shifts, I'd rank it as the best shifting truck transmission I've ever owned.
Old May 13, 2009 | 06:33 PM
billie's Avatar
Just an FYI, but the reason ATF is used in some manual trannies is due to the tighter tolerances and a heavier oil does not get into all the galleries properly especially under load. To each his own, of course, but that is why ATF+4 is the specified fluid.
Old May 13, 2009 | 08:35 PM
RiverRat2's Avatar
How long have you run the Synchro and is it thin viscosity like the Mopar ATF-4????
I was told there wasnt enough clearance to run the thicker Tranny fluid because if the aluminum housing????
What about the transfer case?????
Old May 14, 2009 | 01:13 PM
D-Roc's Avatar
On my second run of it. It is quite thin, almost like ATF, plus if you look at the Viscosity at 100C it is pretty close as far as the Cst numbers go, slightly thincker.
As far as the almuinum housing issue being a reason for not running a "heavier" fluid, that doesn't make much sense.
I run it in the T case as well...good for a manual trany, good for my tcase.
If you're out of warranty, call the the guys at RP and pick their brains. I did, and tried it hesitantly, but then was quite impressed. Especially when I dropped the first change of it, and there was very little metal on the magnet. Atf+4 had a heck of a lot more metal on the plug!
Old May 15, 2009 | 12:19 PM
Belgrath04's Avatar
For the 5.9 G56's ... well I guess other than the gearing the new G56 are effectivly identical ... What is the recomended interval?
And just to be sure they specify ATF+4? havn't looked at service manual, just being lazy.
Old May 15, 2009 | 04:20 PM
SundayMoney's Avatar
I want to say the interval is 60k.
ATF+4 is the fluid
Old May 15, 2009 | 05:23 PM
Jeff in TD's Avatar
I think that's what the book says (60k). I did mine earlier.
