G56 problems
Ya thats definately true. I run around 23 to 2400 rpms at 80 mph. But other than the high revs I love mine. 30,000 miles and no problems, other than the clutch slippin with smarty turned up
is anyone else having problems with the G56?? i'm on my 3rd one, and the 2nd only lasted a couple thousand miles before i lost 1st and 2nd shift forks and locked up the tranny. now the current one with about 1000 miles sounds like a bearing is about to sieze up. i'm just curious if i'm the only one having problems with these.
Can you describe your current bearing sound a little more?
With 80K miles, mine has been making what sounds like input shaft bearing whine for about 6000 miles now, but only when the tranny is cold. With the transmission in neutral and the clutch engaged at idle, there is a whine. Push the clutch in and noise goes away. Once the transmission is warmed up, the noise disappears. Fluid looks fine. I had a transmission shop look at it and they said that I shouldn't worry about it, that transmission noises like that are not unusual, especially after they have some miles on them. Is your noise anything like what I descirbed?
yup
And muddin' and hotrodding around didn't help much either. I can't put my smarty higher than 3 without slipping like crazy, so last week I ordered my southbend 3250 DD clutch. Should be good when I get it installed. A side note, the levels on a Smarty are called CATCHER levels. CATCHER stands for: Clutch And Transmission CHallengER ......
