G56 noise, is it about to fail?
Old Mar 18, 2008 | 05:23 PM
sdaly's Avatar
Hey all,
When my truck is still cold and it's idling in neutral (clutch out), there is a low whine coming from the transmission. If I push the clutch in, the noise stops, and returns as soon as I let the clutch back out again. Once the truck warms up the noise goes away. Is this a normal noise that I just never noticed before, or is it a sign that I'm about to lose an input shaft bearing or something? The engine and driveline are bone stock and I drive it easy. It has about 76K miles on it.
Old Mar 18, 2008 | 05:54 PM
snoyes's Avatar
Sounds like the throw-out bearing is starting to go... Maybe one of the clutch experts will chime in here....
Old Mar 18, 2008 | 06:33 PM
sdaly's Avatar
I was thinking about the throw-out bearing too. But then doesn't the throw-out bearing only spin when the clutch is pushed in and stop when the clutch is let out?
Old Mar 18, 2008 | 07:01 PM
scootertrash35's Avatar
ours have chattered since almost new,with replaced dmf,con o,and con fe
Old Mar 18, 2008 | 07:04 PM
1stGen545's Avatar
No it has just a little pressure on it all the time and spins all the time. When you apply more pressure you can take up the slack from a worn bearing and make it stop squeaking. If it is and it gets worse you need to replace it soon or you could do like this guy did. He kept driving and it sees ed to the input collar and then took out the pressure plate. Then he kept driving with out the clutch and wore out the syncros and broke a tooth off of 3rd gear. Instead of needing a throwout bearing we had to rebuild his trans $1700 (NV4500) and new South bend clutch $750 Con FE. Trust me you will know before it gets to this point.
Old Mar 19, 2008 | 10:25 AM
mikewalling's Avatar
dmf? con o? con Fe? care to elucidate?
Old Mar 19, 2008 | 11:10 AM
sdaly's Avatar
1stGen545, thanks for your reply. I hope you are right. I'd much rather it be a throwout bearing than an input shaft bearing. I'll get it checked out, thanks.
Old Mar 19, 2008 | 05:54 PM
rich's Avatar
wouldnt hurt to change the fluid in it
Old Mar 19, 2008 | 10:04 PM
mmm...diesel's Avatar
Mine has rattled in fifth and sixth gear since it was new. Absolutely pisses me off, but Dodge wouldn't do anything about it. Now it has started to whine in sixth along with the rattle... Sounds like i'll be rebuilding mine soon
Old Mar 20, 2008 | 10:05 AM
sikboater's Avatar
Mine has a noise that you can only hear while pushing in the clutch (kinda like a grinding noise). When the clutch is engaged you can not hear it and when the clutch is disengaged you can can not hear it. I only really notice it if I am really paying attention. Also the truck has to be warmed up to hear it.
I have taken it to a couple of shops, I think it might be a pilot bearing. One shop wanted to replace the clutch and bearings. The other shop thought I should just leave it alone until it changes or gets a little louder. The clutch works great and the shifting is smooth also.
I have changed the fluid but that did not make a difference. For now I am just waiting to it to get a little worse before I drop the money for a clutch, hopefully that is not a mistake.
Does anyone think I am just shooting myself in the foot?
Thanks
Tim
Old Mar 20, 2008 | 11:11 AM
Sniper05's Avatar
Mine moans and groans all the time, It also rattles in fifth and sixth gear and has since new, changed over to syntec and helped alot but still growls at me all the time. My throw out bearing squeels at me so i'll be getting a clutch soon, also because i just ordered my smarty too so i'll kill two birds with one stone!
Good luck
Chad
Old Mar 20, 2008 | 07:05 PM
sdaly's Avatar
Well I just had an independent mechanic look at it (he's my neighbor and has his own shop). He had me push the pedal in and out while he listened underneath, and also tried just slight pressure on the pedal. The noise is definitely a whirring/howling sound like a bad bearing, and not a rattling sound like some of you mention. Anyway, he said there's a chance it might be a throwout bearing, but doubts it. He thinks its an input shaft bearing. He says it sounds like it's in the early stages of failure and that it can wait a week or two (I can't give him the truck right away) and then he's going to dig into it. I'll let you know what he finds out.
Old Mar 20, 2008 | 08:18 PM
XLR8R's Avatar
Have you ever checked the tranny fluid?
Some of the early G56s came from the factory underfilled...
I was just in one last week with ~86K miles for no reverse - barely got a quart out of it with the PTO covers off.
Cheapest thing you can do right now to help is drain & refill with 6 quarts - be sure to use ATF+4 !!!
Old Mar 21, 2008 | 01:28 PM
sdaly's Avatar
Hi XLR8R,
Thanks for the suggestion. Yes, I have checked the fluid recently and it was fine. I change the fluid every 30K miles with 6 quarts of Redline C+ ATF. I fill it right up to the fill-plug which is usually just a tad over 6 quarts. I'm hearing some people lift up the right side of their truck to overfill it. Is this something I should be doing? Could not overfilling it, or using Redline C+ ATF instead of the Mopar fluid, have led to this failure?
Old Mar 21, 2008 | 01:46 PM
XLR8R's Avatar
Sounds like a good maintenance schedule - not sure about the C+ though; probably is fine, just like ATF+3 would be OK - but I use ATF+4.
Not overfilling wouldn't cause any durability issues.
The fluid always looked good when drained?
Depending on how loud the offending noise is, I doubt I would yank the tranny unless something was broke or about to be.
