G56 Failure
Old Sep 9, 2006 | 01:40 AM
  #106
bigd6.6's Avatar
Originally Posted by XLR8R
Wow - that's more wasted G56's in one post than I've ever heard of total !
Easy now i had two also but maybe i was to hard on them.
Old Sep 9, 2006 | 03:45 AM
  #107
PourinDiesel's Avatar
The reason the 5600 is no longer produced is because Chrysler was the sole customer of the nv5600.
The nv5600 was developed for DCX.
Old Sep 9, 2006 | 06:52 AM
  #108
XLR8R's Avatar
Like I said = WOW
Ramasaur's dad broke 2 G56s and has two friends facing the same problem... that sounds like 6 trannys to me
... but I don't think he meant to upstage ya!
Old Sep 9, 2006 | 09:31 AM
  #109
packard8's Avatar
Like I said = WOW
2-4-6 tranny failures in a row? Sounds like a manufacturing alignment problem (bellhousing, engine block, tranny case).
Unless there is more to the story………….
Old Sep 9, 2006 | 09:50 AM
  #110
Right, that must be it!
Old Sep 9, 2006 | 10:04 AM
  #111
sawboywv1's Avatar
I read that Cummins was changing the ISB blocks to Aluminum for 07'... to match the G56 man trany!!!!
Old Sep 9, 2006 | 10:17 AM
  #112
XLR8R's Avatar
Exactly! - ???
Old Sep 9, 2006 | 10:20 AM
  #113
XLR8R's Avatar
Now, hold on - don't want to throw the OEM under the bus prematurely...
maybe they're all sledpullers!
Old Sep 9, 2006 | 10:21 AM
  #114
XLR8R's Avatar
Where will they get all the beer cans?
Old Sep 9, 2006 | 10:28 AM
  #115
P.J's Avatar
P.J
Righto.
There was a guy here a while back that was complaining about a toasted clutch @15K miles. He was upset becuase they wouldn't waranty the clutch itself (wear item)
"What, your not supposed to be using the skinny pedal and the clutch to take off?"
Old Sep 9, 2006 | 10:40 AM
  #116
HOHN's Avatar
It is confirmed, G56 is junk in my book.
Because it breaks when punished with the abuse of sledpulling??
Old Sep 9, 2006 | 10:43 AM
  #117
sawboywv1's Avatar
I gonna step up my personal consumption to increase output.
Old Sep 9, 2006 | 10:44 AM
  #118
RCinMesa's Avatar
I've owned two '06 trucks with the G56. They were both very different transmissions. The first G56 was very notchy and stiff, but after a few thousand miles it smoothed out nicely. It pulled heavy everyday for over 23k miles. It did fine. I got another '06 with a G56, and it was very smooth from the beginning, it towed heavy everyday too. However, at about 1500 miles, it made some very loud squealing noises under acceleration, and while letting off the pedal. You could feel the vibration through the shifter. Sounded bad to me, like bearings perhaps. After that, 6th gear developed an increasingly loud and perceptible vibration and rattling noise. It continued to shift well though. I am at the same job, but don't pull trailers anymore, so I got yet another truck. This time a dually with an automatic.
Old Sep 9, 2006 | 12:04 PM
  #119
packard8's Avatar
Exactly! - ???
A guy on the FordDiesel.com forum was whining about Ford not warranting a rod thru the block of his 6.0. Someone looked back thru his earlier posts and noticed that he had an aftermarket turbo, big swamp injectors, a box, a chip and was squirting both NOS and propane and he liked to street race……
Often there is “more to the story”…………
Old Sep 9, 2006 | 04:12 PM
  #120
P.J's Avatar
P.J
Thank You.
