Fuel Pressure on my truck
Old Sep 23, 2007 | 12:59 AM
Cloride's Avatar
Can anyone please tell me what the normal fuel pressure on my 2005 Dodge 3500 5.9 liter should be. I have a Quadzilla commander and it says 10 psi when I idle, but really drops down when I really get in the gas. I need some guidance on what I should do if anything.
2005 Dodge 3500 Silver, Volant Air Intake with Ram air, MBRP cat back exhuast with cat delete, Quadzilla Standard Module with controller.
Old Sep 23, 2007 | 07:50 AM
SSminnow's Avatar
10 @ idle is fine for a stock LP. Under boost, look for 5-7 PSI.
MIne would idle @ 5-7 and drop to 2-3 under boost, an then hit 0 under boost, and that is when I replaced the LP
Old Sep 23, 2007 | 01:37 PM
Cloride's Avatar
Is my lift pump bad or do I just need an aux LP? BD sells one but I just don't know if mine is going bad. By the way mine does the exact same as yours.
Old Sep 23, 2007 | 02:45 PM
2007 5.9's Avatar
I also have 9-10psi at idle and cruising with low boost, and when I nail it I can pull it down to 5-6psi. Not too worried yet
Old Sep 23, 2007 | 03:15 PM
kinghomes's Avatar
Nailed I am pulling 0 or near 0 , but I am worried about guage accuracy at the level. I can pull it very near or at 0 punched. I also have had stall. Seem to be a little slow now also.
Aboyut to replace intank with foss today. I'll let you know
Old Sep 23, 2007 | 03:19 PM
rustyshakelford's Avatar
look into a fuel system from gdp or fass. it will cure your low fuel pressure on hard acceleration issues
brett
Old Sep 23, 2007 | 03:27 PM
Cloride's Avatar
does the GDP system totally bypass the OEM lift pump and does it have the capability of using a fuel pressure sender??
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
