Fuel Issue Please Help
Old Jul 23, 2008 | 10:05 PM
jcg's Avatar
jcg
Hey I am wondering if anyone has had the same problem that I am having and what they did to fix it. My 03' just started dying while I it is idling. If it doesnt die then it struggles through the problem and rev's itself back up pretty aggressively. I am going to start with the fuel filter tomorrow and see what happens. I am open for suggestions as this is my first diesel.
Old Jul 23, 2008 | 10:19 PM
DiezelSmoke's Avatar
Sounds like air in the fuel. Check fuel line that is loose or rubbing on something. This will usually cause hard start also.
Old Jul 23, 2008 | 10:26 PM
6 Shaker's Avatar
Sounds like it is possibly your lift pump starting to die. Does it still have the engine mounted lift pump?
Old Jul 23, 2008 | 10:50 PM
snoyes's Avatar
How many miles on the truck? Were you having problems with it taking alot to get it to turn over, or did it happen suddenly. Possible bad fuel? Have you filled up recently? Was the truck sitting for an extended period? Drain the fuel out of the bowl and see if you got water in there....
Old Jul 23, 2008 | 11:12 PM
jcg's Avatar
jcg
I filled up about three weeks ago and had no problems. It has no problem turning over, it just happened out of nowhere. I drained the water tonight and there appeared to be no water mixed with the fuel. I talked with a dealer and they said it possible is a idle performance fault. They also said to do a diagnostic on it would cost around $200. I would rather spend the money on parts.
Old Jul 23, 2008 | 11:18 PM
vzdude's Avatar
DTR's 'Go to Guy'
Cycle the key from off to on ( not cranking) 3 times ending in the on position. Any codes will read out in the odometer screen. I can help ya with more diagnostics after you read codes. Like said above though......sounds like a lift pump issue.
Old Jul 23, 2008 | 11:33 PM
jcg's Avatar
jcg
All right I ran outside and the code came up as P 0602. If it is the lift pump what does everyone suggest?
Old Jul 23, 2008 | 11:47 PM
vzdude's Avatar
DTR's 'Go to Guy'
P0602 Checksum Error
You have any mods to the truck?
Old Jul 23, 2008 | 11:48 PM
vzdude's Avatar
DTR's 'Go to Guy'
P0602-CHECKSUM ERROR
When Monitored: While the ignition is on.
Set Condition: A deviation between the ECM memory and a stored calibration.
POSSIBLE CAUSES
FLASH ECM
ECM
TEST ACTION APPLICABILITY
1 Using the DRBIIIt, reflash the ECM with the proper calibration for the particular
truck.
Is the flash successful?
ENGINE- 5.9L
CUMMINS 24V
DIESEL
Yes ! Repair complete.
No ! Go To 2
2 With the DRBIIIt, read DTCs.
Did P0602 set after the reflash?
ENGINE- 5.9L
CUMMINS 24V
DIESEL
Yes ! Replace the ECM.
No ! Test Complete.
182
DRIVEABILITY - DIESEL
Old Jul 25, 2008 | 10:35 PM
jcg's Avatar
jcg
fuel issues
hey while i was messing with the truck a new code came up as P 0480. Hopefully it does not mean anything bad.
Old Jul 25, 2008 | 10:39 PM
vzdude's Avatar
DTR's 'Go to Guy'
P0480 Fan 1 Control Circuit
No biggie.....I've had that one come and go from time to time. Just keep an eye on the temp guage. If you start continually running hot or have poor a/c then you may want to look into replacing the fan clutch.
jcg
Jul 24, 2008 09:37 AM
getblown5.9
Feb 16, 2008 06:57 PM
SuperiorRam
Mar 15, 2007 03:10 AM
BNC04
Sep 26, 2006 12:51 PM
DDysput
May 5, 2004 07:44 AM
