1-2-1-2 shuttle shift problems
Old Jul 20, 2008 | 11:48 AM
bigray's Avatar
hello,i have a 05 dodge with a 48RE trans it has right at 84k miles.it started do the 1-2-1-2 shuttle shift thing.so i replaced the gov pressure switch and the gov press soli.and filter and fluid.It did help the problem. SOME. but did not fix it totally.does it need to go get the band adj.or flash the comp.or ??? now i got all the fancy names from reading here in the forum.thanks for any help..
Old Jul 20, 2008 | 01:06 PM
bigray's Avatar
Update.went for a drive after cleaning all the plug in connectors on the trans.it seems to shift alot better,BUT.if you stand on it.it shifts a little late around 3200rpm and if you let it shitf into 2nd and lean back on it.it will shift back into 1st and go to 3200 plus.and almost never shift back into 2nd till you lift a little.it really seems like it wants to down shift back in to 1st to easy.after shifting into 2nd..just a nother way of saying what its doing.at a stop light,light goes green and you need to get over,and you stand on it.revs a little high and its late on shiting,then you lift,let it shift,then lean back on it and then it will shift back into 1st.
Old Jul 20, 2008 | 06:03 PM
BigIron70's Avatar
Cummins Guru
Try having PCM updated may help, several TSB's for trans shifing problems.
Old Jul 20, 2008 | 06:10 PM
JDiepstra's Avatar
I got a valve body from HTS and now my truck shifts sweet!
Old Jul 20, 2008 | 08:16 PM
bigray's Avatar
thanks for the replys.the person i got this truck from never took it to the shop.did his own oil changes,trans fluid,Ect.so i know for a fact it has never had any factory TSB's done.probably taking it to the dealer in the morning.will keep everybody posted.
Old Jul 20, 2008 | 08:28 PM
Ridiculies's Avatar
I too have an aftermarket valve body, and it has changed the shifting of the truck. Not sure if you want to spend the $ but, an aftermarket valve body and TQ make these 48RE come to life.
Old Jul 20, 2008 | 09:17 PM
JDiepstra's Avatar
And a valve body is only about four hundred bones and a lot of people can change them themself, or with a buddies help.
Old Jul 20, 2008 | 11:46 PM
woodrep's Avatar
Isn't Dave Goerend having a sale on his VB's right now? I thought I read 200.00 or something crazy like that.
Old Jul 21, 2008 | 04:38 PM
2wheel-lee's Avatar
I didn't have the shuttle shift problem until I got my Goerend VB (and installed by a Goerend dealer). Then to fix it, I was told that I needed some $250 module (I bought it but haven't installed it yet). My tranny shifted much better at lower speeds when it was stock.
Old Jul 21, 2008 | 07:48 PM
woodrep's Avatar
That's extremely odd. Have you actually called Dave Goerend himself on this one? I would find it hard to believe that he would recommend an electronic shift enhanser to cover this one. Was it a DTT or TS that you were told?
Wood
Old Jul 25, 2008 | 11:25 PM
bigray's Avatar
got truck back today,it does seem to shift better.but still not totally fixed.WHAT NOW.i had already replaced the press sol.and the press transducer.but they were not mopar brand.the dealer was wanting to put there brand in.wasnt really sure if i wanted them to do that. yet.HELP....what would you do.Do i need a new valve body to fix this or ??? if i need a valve body what brand...thanks ray
Syndicate
16
Feb 15, 2009 05:36 PM
bigray
Aug 31, 2008 03:02 PM
mike smith
Apr 13, 2008 10:12 PM
JORDAN
Feb 1, 2008 12:54 PM
