Fuel Fliter
Old Jul 29, 2005 | 06:26 PM
turbo_2500's Avatar
Fuel Fliter
How do you know when it is time to change the fuel fliter? Reason i ask is I'm going to start to run bio diesel and people say that it clogs you filter on the first tank or so.
Old Jul 29, 2005 | 06:51 PM
Chip's Avatar
Turbo_2500,
You should change your fuel filter at least every12-15k miles, I change mine with every oil change, which is around every 9k miles, I run Amsoil and the drain intervals are a little longer. Just my .10 cents. Let us know how the bio-diesel burns !!
Chip
Old Jul 30, 2005 | 10:07 AM
Texcowboy9's Avatar
I change my fuel filter every 10k. I have heard that after changing to biodiesel you should change the fuel filter after about 2 tanks. As easy as they are to change this should be no problem.
Old Jul 30, 2005 | 07:36 PM
gsbrockman's Avatar
If that's the case, seems as if most of the cost savings are going out the door in more frequent fuel filter changes....even if you use & install your own Fleetguard #FS19579 filter at $12.00 or so.
Greg
Old Jul 30, 2005 | 08:39 PM
angleiron's Avatar
i change the fuel and air filter every 15k. Dealer wanted to charge me $160.00 to change both of these filters...I could have bought enough of each to get me to 75K miles for what they wanted!
Old Jul 30, 2005 | 09:16 PM
Texcowboy9's Avatar
Maynard, I meant to say the FIRST two tanks.
Old Jul 31, 2005 | 11:02 PM
B.Law's Avatar
I'm not sure I follow, why just the first two tanks?
Old Aug 1, 2005 | 08:08 AM
Texcowboy9's Avatar
Because it suposedly cleans out the fuel system. My knowledge on this is from reading what others have written only, I have not as yet tried Bio.
Old Aug 1, 2005 | 05:31 PM
stevenknapp's Avatar
FWIW, I've run bio B20 on/off many times. Never had to replace the filter because of the B20. I think the warning is more for older trucks with tons more crud.
I did replace it at 7500, 15k, and coming up on 30k for the next change.
Old Aug 2, 2005 | 11:59 AM
walt_mink's Avatar
I dunno about that - I had mine get so clogged that I could barely get home. It was my first tank of Bio (B100 - big mistake) and I had 7500 miles on her. Now, I'm not sure if it was dirty Bio, or a dirty tank, but I'm paranoid enough to always keep a spare filter and wrench with me at all times. That's not to say that I don't still run Bio - I do - but I'm cautious about it now. I would run a couple of tanks of B20 to get started and then change the filter out. After that - start running on beans and enjoy!
Old Aug 2, 2005 | 05:19 PM
I dunno about that
I do. It's my truck. I've done this. I've had no problems. I've been running B20 on and off the life of the truck. I changed the filter at 7500 myself, looked pretty clean. Dealer did it at 15k. Coming up on 30k.
I always have a spare filter and tools to change it in the truck. That's probably what keeps it OK.
dansdodgediesel
Sep 2, 2008 06:59 PM
CanuckRam
Aug 19, 2008 08:09 AM
lab
16
May 30, 2004 03:15 PM
antknee
May 26, 2004 03:35 PM
