Fuel additive
Old Feb 20, 2007 | 09:31 PM
TxnBorn88's Avatar
Fuel additive
I have been looking around to see what kind of additive to add when I fill up and came up with power service. Is that a pretty good additive? i really have no clue about this. what are yall opinions on what to add and what not to. thanks for the help
Old Feb 20, 2007 | 09:55 PM
roadgeneral's Avatar
I use Stanadyne Performance Formula. It addresses any lubricity problems that ULSD may be causing, plus it improves cetane for performance and it is an anti-gel for winter use. They have other formulas that are more specific to problems; such as cold weather gelling or waxing of the diesel. DO NOT USE any additive that contains alchohol. It holds water in suspension in the diesel and will cause damage to your pump as it passes through. I don't know if Power Service contains alchohol or not.
Old Feb 20, 2007 | 10:10 PM
wrm's Avatar
wrm
first choice stanadyne preformance formula. best prices on ebay. second choice meaner power cleaner by howes is good in warm weather has no anti gel sold at truck stops.
Old Feb 20, 2007 | 10:23 PM
RocketJohn's Avatar
I tried the Power Service Fuel Supplement in the white bottle... quieter motor... my friends recommended... you can get in a lot of places (i.e.: WalMart, Advance Auto Parts, etc.)
Old Feb 20, 2007 | 10:29 PM
TxnBorn88's Avatar
Do i have to worry about changing the fuel filter after I run a tank of fuel through with the additive. i only have about 20000 miles on the truck just curious about how much gunk could be bulit up
Old Feb 21, 2007 | 01:49 AM
danc46's Avatar
Change that fuel filter as soon as possible!!!! It's not a good idea to go much past the recommended fuel filter change at 15K. Diesel oil is dirty by nature and will clog up a filter after a period of time.
Using a fuel supplement will make your truck run noticeably quieter and give you more mpg.
Old Feb 21, 2007 | 09:05 AM
wrm's Avatar
wrm
second on changing the fuel filter now .very very very very very important.
Old Feb 21, 2007 | 09:33 AM
PoorMansCat's Avatar
Personally, I change the fuel filter with every engine oil change. When our company got these new D-Maxes, GM said that once every 15000 miles was reccomended and use standadyne JR. with every fill up. We had so many failures that I couldnt even begin to list them all. They have came back and said that the filters won't last that long, but gave no reccomendation about when they should be changed. There are six of theses trucks in our dept. and we have found, thru failures, that its best to change at every oil change. The quality and cleanliness of on-highway diesel fuel varies greatly between suppliers, delivery trucks, stores, weather, processing variations...etc...
We also got away from the Standadyne JR after having numerous failures even though we were changing filters every 5000 miles and started running the Caterpillar fuel conditioner. My service truck hasn't had a fuel system related failure since then, that was approx. 60,000 hard miles ago.
Old Feb 21, 2007 | 05:17 PM
TxnBorn88's Avatar
i change it with every oil change which around 5000 miles but i just changed it and was curious if i should wait the 5000 miles or change it after i run a additive through a tank
Zeppe807
25
Nov 16, 2010 08:00 AM
rjmelehan
0
Nov 30, 2009 01:02 PM
Dec 23, 2002 07:42 PM
doodah
16
Dec 14, 2002 10:20 AM
MARKY MARK
Nov 19, 2002 09:37 PM
