frustrated 06 hard start
Old Dec 3, 2012 | 12:25 AM
47Dodge's Avatar
Originally Posted by patmedic
Well it shows basically a battery code . As mentioned earlier they have been acting weak. Sounds like a good battery check needs to be done. I will post the final results tomorrow. thanks to all that helped
I know on the older Dodge Ram gassers they could be touchy with a weak/bad battery. It may have enough poop to turn over but the computer and systems didnt like it and it would create lots of funky problems.
On the diesel weak batteries wont spin the motor over fast enough to get the cylinders to fire. You need the pistons to create compression fast and get that bit of heat made from compression to start. Shot of ether just ignites easier then diesel.Maybe thats your problem.
47
Old Dec 3, 2012 | 07:54 AM
Shorts's Avatar
Weak batteries make these trucks do weird things. When you get it checked be certain to include a load test. It might read ok just sitting there, but when you try to crank it might be so weak it'll need replacing. Something else to consider, change both at the same time.
Old Dec 3, 2012 | 09:36 AM
butchb's Avatar
I hate to beat the dead horse. I am at work at the fire station and our Internet access is poor so searching here is impossible sometimes. My truck started to crank a long time cold after setting overnight and now will not start unless I use a little starting fluid. It does help if don't have it on a incline and plugged in at night. Is the lift pump in the tank for this year? I tried the pull code thing by turning the key but did not see any codes. Any help would be great..... please help... thanks
I'd be REAL CAREFUL spraying ether in the intake. These motors use a grid heater similar to a toaster element. Glowing red coils plus ether equals BOOM!!
Old Dec 3, 2012 | 10:06 AM
rockcrawler304's Avatar
Most importantly this!!! ^^^^^
Second I would bet it is just your batteries.
Old Dec 3, 2012 | 11:51 AM
patmedic's Avatar
Well I went to Orielleys and had my batteries tested and it show that one was weak so I replace them both with 900 CCA , cleaned and protected the terminals . Now I will wait until tomorrow morning to see if it is fixed. Yep I strongly agree with the ether comments going BOOM is not a good option.
Old Dec 4, 2012 | 09:03 PM
patmedic's Avatar
Update : I started the truck this morning without plugging it in and it gets pretty cold where I live and it started great. I will see how it starts in the morning here at work and if it starts OK . I will call it fixed. Thanks to all again for your help.
Old Dec 5, 2012 | 10:31 AM
Great news so far.
michcumm
16
Apr 10, 2008 08:49 PM
Wolff
Apr 7, 2005 10:47 PM
cumminsbanshee
Feb 23, 2005 07:50 AM
G1625S
Jan 2, 2005 08:19 PM
VPI
Dec 12, 2004 10:02 PM
