frustrated 06 hard start
Old Dec 2, 2012 | 11:46 AM
patmedic's Avatar
I hate to beat the dead horse. I am at work at the fire station and our Internet access is poor so searching here is impossible sometimes. My truck started to crank a long time cold after setting overnight and now will not start unless I use a little starting fluid. It does help if don't have it on a incline and plugged in at night. Is the lift pump in the tank for this year? I tried the pull code thing by turning the key but did not see any codes. Any help would be great..... please help... thanks
Old Dec 2, 2012 | 11:51 AM
johnh's Avatar
are the grid heaters working???
Old Dec 2, 2012 | 02:01 PM
patmedic's Avatar
Thanks I will look at this tomorrow when I get home. Probably going to get the batteries tested also . Seems like it just cranks for a short time before they are weak. Anyone else have any suggestions?
Old Dec 2, 2012 | 05:45 PM
06RAM2500's Avatar
There are a few things you can do to trouble shoot what the issue might be.
First the lift pump: turn the key to the ON position and you should hear it kick on for a few seconds. Bump the starter and it'll run long enough for you to open the drain on the filter bowl. If fuel runs out at a pretty good stream, lift pump is good.
Second, injectors: On top of the engine, next to the valve cover, there will be two electrical connections. Those are for the injectors. What you can do is unplug them and use an ohm meter to check the resistance of the solenoids. What you'll see is this ------. First two pins are #1, middle pins are for #2, last pins are #3. Connection by the firewall: front pins are #4, middle pins #5, end pins are #6. If any of them read more than 1.0, that injector is shot. A good reading will be .4 to .7.
Old Dec 2, 2012 | 06:00 PM
patmedic's Avatar
I do hear the lift pump in the tank. I will have to wait until tomorrow to ohm check the heat grid and injectors. I can not get the codes to come up on the OD screen by turning the key on and off 3 times. So I will go to O'reilly's in the morning and have them check my batteries and my codes. It seems my batteries are weak. thanks for all the help.
Old Dec 2, 2012 | 08:01 PM
Tobin's Avatar
Does it white smoke once it gets started?
Tobin
Old Dec 2, 2012 | 08:07 PM
patmedic's Avatar
Not that I notice it seems like it runs normally after started. maybe a little darker smoke at first.
Old Dec 2, 2012 | 08:14 PM
patmedic's Avatar
Do heat grids throw a code? It starts right up when plugged in after setting all night.
Old Dec 2, 2012 | 09:01 PM
Shorts's Avatar
To get the codes try holding down the trip button while doing the key thing.
Old Dec 2, 2012 | 09:04 PM
patmedic's Avatar
thanks I will try that.
Old Dec 2, 2012 | 10:30 PM
patmedic's Avatar
well I tried it with the trip botton down and the codes displayed are s116, c447, .281, hr3655. if any of this helps. I tried looking up the codes and I could not find anything on these codes. Anyone have any Ideas?
Old Dec 2, 2012 | 10:32 PM
patmedic's Avatar
The more I read on the 06 I am not sure if you can read the codes on the OD. If anyone knows for sure please advise me. Thanks
Old Dec 2, 2012 | 10:43 PM
baker01's Avatar
06 will give codes, turn the ignition from off to on quickly three time, leave in the on position the third cycle. codes will show in the odomiter. If there are no codes you will get a -- display. You do not need to hold the trip reset that will give you hours on the motor.
Old Dec 2, 2012 | 11:54 PM
patmedic's Avatar
That worked this time I got code p2509 looking it up now.. thanks
Old Dec 3, 2012 | 12:05 AM
patmedic's Avatar
Well it shows basically a battery code . As mentioned earlier they have been acting weak. Sounds like a good battery check needs to be done. I will post the final results tomorrow. thanks to all that helped
