Front Universal
Old Jun 14, 2008 | 08:09 PM
Dynocon's Avatar
Front Universal
With 78K I think I heard the from U joint creak a little. I have read that the NAPA HD are pretty good. How hard are they to change? Any tips?
Old Jun 14, 2008 | 08:58 PM
mikmaze's Avatar
are you talking the u joint on the axle or the front drive shaft ??????? axle is a pita thats why i let the dealer do mine for free o yeah, btw, had the front driveshaft replaced that way too !
Old Jun 15, 2008 | 01:33 PM
Dynocon's Avatar
Not sure. I put it 4 wheel and it clumked on the front left, I think. That is the only time it did it. I assume it is the U joint.
Old Jul 31, 2008 | 05:01 PM
Dynocon's Avatar
It is the u joint on the front drivers wheel. How hard is it to change?
Old Jul 31, 2008 | 07:39 PM
JP-4.5's Avatar
I just had mine changed. I was going to do them myself but could not get the hubs off. A local diesel shop did mine. They had to cut the stock hubs out with a torch!! Luckily I had decided to do the free spin hubs before attempting this. I would have some hubs on hand if you are going to attempt this. Also be sure that ball joints and tie rod ends do not need replacement. Now is the time to do them if needed.
Good Luck..
Old Aug 1, 2008 | 09:34 PM
booman70's Avatar
Did both of mine @ about 40k dont use a puller on the hub press it out from behind using the power steering. The first one was a real pita till I figured it out the second one was much easier.
BC847
Jul 30, 2013 08:48 PM
KWKING
Nov 29, 2012 09:42 PM
schoust
Nov 27, 2009 09:30 PM
ollie32
Aug 8, 2007 11:05 PM
Nav
Jul 21, 2006 09:19 AM
