Front shock replacement
Do the springs have to be removed in order to get the shocks out?
For the lower nut, the access hole that faces the rear is large enough for a 3/8" extension but not big enough for a socket - any thoughts?
thanks
scott
thanks
scott
No need to remove the coil springs. You just remove the shock tower on the top (three small bolts), then remove the bottom bolt out the front. You don't need to hold the bottom nut from turning -- it's spot welded or somehow fastened to keep it from turning. Then you pull the shock out from the top.
I fit an impact socket right in the hole. On the passenger side I pulled the tower with the shock, on the driver's side I didn't have room for that so I loosened the top shock nut, then removed the tower, and pulled the tower off separately.
freight train
22
Mar 25, 2013 04:46 PM
Diesel_Power_2
Mar 21, 2011 04:17 PM
stumpjumper
Aug 21, 2007 07:14 AM
Tommy93w350
Jul 7, 2006 01:35 PM
