HELP!!Wont start,but turns over.
Old Mar 25, 2010 | 11:15 PM
newsboy19's Avatar
I have a 2003 laramie Cummins5.9 turbo diesel. The problem right now,well it wont start.its getting diesel to the injectors,it has oil,it is not below35degress outside, it will turn over an want to start.but the truck will not start!fuel is being pumped good,anany suggestions?an i live in texas.
Old Mar 26, 2010 | 09:23 AM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
so, i'm curious how you know it's getting fuel to the injectors? Do you have a fuel press gauge after the filter and right before the injector pump? How much press do you have?
Are the grid heaters coming on? Wait to Start light working?
do you hear the lift pump working when you turn on the key?
Any codes?
We need more info in order to help much.
Old Mar 26, 2010 | 10:02 AM
trainermg's Avatar
Bet your not getting fuel to them or it will run!
Old Mar 27, 2010 | 06:56 PM
newsboy19's Avatar
we cracked the injectors a little bit an diesel came out.so yeah thats how we checked it.i have it at a diesel shop!mechanic said that doesnt think its getting enough pressure to turn it over.well thanks!
Old Mar 27, 2010 | 07:16 PM
nofatum's Avatar
You probably have a leaking injector, there are two kinds, the latter of which you would want. Number one type will dump fuel into the crankcase, the other will let fuel leak back to the tank. Both types will not let fuel pressure build enough in the common rail for the ECM to signal start. I had the latter on #3 injector.
Old Apr 3, 2010 | 01:27 PM
Ram Guy's Avatar
You may want to rule out the factory security before you start digging too far into pumps etc...Make sure you don't have the security light on. Maybe you need to relearn the keys (at the dealer).
Just something else to check.
Old Apr 3, 2010 | 01:52 PM
alltimelow1's Avatar
Only time I ever had that happen to me on my truck it was the lift pump gone south!
newsboy19
20
Jul 14, 2015 06:14 PM
jjrightmire1973
Aug 22, 2008 12:01 PM
smithpre
Sep 14, 2007 03:41 PM
nukewaste
Aug 16, 2007 09:47 AM
