Front Hub Warranty??
Old Feb 21, 2009 | 09:44 AM
SJL's Avatar
SJL
I have a 2005 4x4 Laramie. Do any of you know if the front hub bearings are covered under warranty? The truck has 60K miles. The truck is covered under the extended 7 YR/70,000 mile drive train warranty. Took the truck to the dealer and they say this is not covered. Thanks.
Old Feb 21, 2009 | 10:07 AM
rich's Avatar
not part of what they consider drive train
Old Feb 21, 2009 | 11:05 AM
Colo_River_Ram's Avatar
With age comes the cage
I'm assuming it was the maximum care extended warranty that you have...
Click on the My Current Plan tab and put in your info and it should tell you whats covered:
http://www.dodge.com/en/service_cont...les/index.html
Old Feb 21, 2009 | 11:56 AM
SJL's Avatar
SJL
no just what came with the truck 3years/36000 and the drive train warranty 7year/70000 i guess they dont consider the front hub bearings as part of the axle housing and internal parts
Old Feb 21, 2009 | 12:22 PM
OK,
If you are going to have to buy parts you might want to think about adding the free spin hub kit with re-packable wheel bearings.. do a search of this site for the kits and install..
Old Feb 21, 2009 | 01:22 PM
SJL's Avatar
SJL
truck is already at dealer. they submitted the part #s to chrysler to see if there covered under power train warranty. they told me there not . just under 1400 dollers to replace both.i was hoping they would be covered .
Old Feb 21, 2009 | 02:27 PM
rich's Avatar
1400 to replace i believe those parts only cost about 300 each last time i bought some
Old Feb 21, 2009 | 03:42 PM
mini14's Avatar
it should only take 30-40 min. per side to install, rock auto has them for $214.00 last time i checked. u r getting bent over
Old Feb 21, 2009 | 05:51 PM
OOPS's Avatar
You can almost get a free-spin kit for that price.
Old Feb 21, 2009 | 07:27 PM
Guardrail's Avatar
Don't let the dealer bend you over like that. I thought I had a bad hub and the dealer quoted me $450.00 parts plus 2.5 hours labor. I found a better part (national) at O'Reilly Auto Parts for $240.00. Turned out it was my left axle U-joint.
I took it to a local garage and they charged me 2 hours labor and guess what.... that included removing the hub to get to the U-joint.
When I asked the dealer parts dummy why their parts were so high he replied, "It's an OEM part." I told him the first OEM part went out at 70K, what make him think I wanted another POS to put back in there?
Old Feb 21, 2009 | 11:37 PM
mini14's Avatar
u can get the oem hub its skf, i think e.b. atmus has it for $168.00. id stick with timken or bca
Rafter B
Jan 11, 2009 08:40 PM
yfz431
Feb 5, 2008 06:57 AM
DiEseLjunKy
32
Dec 27, 2007 07:37 AM
Crimedog
Feb 27, 2007 10:39 PM
