Front axle u joint replacement trouble!?!?
Old Mar 26, 2009 | 07:47 PM
mattyfz450's Avatar
Ok so i am in the process of replacing my front axle u joints (wheel joints). So far i have removed the tire, brake caliper, disk brake, and loosend the 4 bolts on the back side. and now i can not seem to get the hub and bearing separated...i have tryed using the socket and extention with no luck ( i may be doing it wrong if anyone can refresh my memory on exactly how it is done and which bolt to put the extention on i would appreciate it). i am also not sure what kind of puller will work. And do you have to remove the ball joints also??? if anyone can point me in the right direction i could really use it.
Old Mar 26, 2009 | 08:14 PM
ptm600's Avatar
Here is a link to MR.GADGETS write up on how to do it. This should answer all of your questions, if not ask again.
Paul
https://www.dieseltruckresource.com/...d.php?t=217250
Old Mar 26, 2009 | 08:46 PM
booman70's Avatar
use lots of pb blaster or your favorite penetrating oil
Old Mar 27, 2009 | 06:15 AM
mattyfz450's Avatar
after the hub and bearing is separated will the axle and u joint fit through the hole in the spindle where the bearing came out of ? i havent got the bearing separated yet but it seems like even when i do that the axle and u joint wont fit through the spindle, but im probably wrong?
Old Mar 27, 2009 | 08:03 AM
booman70's Avatar
yes it will fit
sootnsmoke
Sep 23, 2012 12:26 PM
ride_a_hd
Mar 18, 2012 01:53 AM
38146
Apr 12, 2010 08:40 PM
quicksilvr
Mar 17, 2010 11:18 PM
