Free heater grid delete mod
Since I'm cheap I figured I would gut the heater grid for a free mod and try to gain some air flow. Not expecting alot but here in south Texas I figure what the heck. Fire away with questions if you have any. I think all I needed was a 10,11 and 12 mm wrenches/sockets for the job. I'll be doing another one soon and I'll try for a complete write up.
Mike
EDIT: Will add pics later this evening
Mike
My grid has been deleted, my relays are still plugged
in, on cold days I get low volt cel. I clear them but
it comes back when it gets cold again. Did you find a
way around this. I see you are Tex you may not get
cold enough to happen.
Something I have noticed on the 03s, both trucks will still pull the voltage down on a cooler starts as if it's still cycling for the grid heater. Maybe this is why I'm never get a CEL, not sure. Pics will be up this evening, and I should be doing another truck pretty soon, I'll try to get some more pics.
if you do not wait to start you will not get the cel. any time the truck is below 50* start the truck as soon as you turn the key on. you are better off cutting the two grids off rather than trying to remove them
http://i1141.photobucket.com/albums/...rljr48/212.jpg
For me it is also an air restriction, so why not take it out. Keep in mind I see maybe 10 days of the year in the teens so cold starts are very seldom. This truck I bought had a block heater cord installed so in a worse case situation, I can just plug 'er in.
Red3quarter
Nov 8, 2008 04:11 PM
DWitcher
Nov 7, 2007 08:26 AM
CL2000
31
Jul 17, 2007 02:25 PM
98.5POS
29
Dec 23, 2006 11:39 AM
