Flushing the radiator
Old Mar 17, 2006 | 02:53 PM
TexasCTD's Avatar
Can anybody give me any advice on flushing the radiators in our trucks?
How often? Any particular product?
My truck is an 04.5 that I purchased at the end of July 04. 38,000 miles.
Should I be doing something around the 2 year mark? Also, what do you recommend for replacing hoses and the serpentine belt? I have had no problems, that I am aware, with any of them. Thanks.
Old Mar 17, 2006 | 03:56 PM
rammtuff's Avatar
Check the PH in your coolant. You should get a couple hundred thousand out of it with additives. Hoses these days should last 10 years. Serp belt depends on wear, cracking etc. Mine is still original.
Old Mar 17, 2006 | 06:10 PM
BigBlue's Avatar
I've flushed mine once in 96k miles. If you do it, I recommend that you go and buy the thermostat from dodge. It's going to cost a pretty penny but it's worth it. I bought one from o'reilly's and it didn't open up until 220* and then it'd drop and climb right back up. Put one in from dodge and it won't go over 190* now.
Old Mar 18, 2006 | 02:00 AM
TexasCTD's Avatar
Ok, I guess based on these comments I will just leave it alone for now. Thanks!
Old Mar 18, 2006 | 02:17 AM
1sttruck's Avatar
When I flush the cars I just use new coolant mixed 50/50 with water, drain it, and add new coolant mixed 50/50 with water. Target has Prestone extended life stuff for about $6 a gallon, and distilled water is less than $1 a gallon. I planned on doing the same in the truck, using the correct coolant (zerex g05 or something).
ckennedy
33
May 21, 2007 01:45 PM
serious
Apr 5, 2006 03:41 PM
D.S.
Mar 10, 2006 08:39 AM
apache
May 18, 2005 07:58 PM
Rayzor
Aug 19, 2003 07:52 AM
