Fluid capacities of 3rd gen diesels
Old Apr 6, 2013 | 11:57 AM
sallyman1's Avatar
This spring I wana change fluids again. What are the fluid capacities of:
Front diff:
Rear Diff:
Transfer case:
Has anyone ran the amsoil synthetic 75w90 in diffs? same as SEVERE GEAR?
Amsoil ATF in transfer case?
thanks any info would be appreciated
Old Apr 6, 2013 | 03:05 PM
sallyman1's Avatar
Any1?
Old Apr 6, 2013 | 06:28 PM
GASKICKER's Avatar
Front diff:
Rear Diff:
Transfer case:
Ive run Amsoil in my rig for quite some time; however, I couldnt tell you the exact capacities - seems like all 3 were around 1.5-2 qts each.
Old Apr 6, 2013 | 10:11 PM
Dr.Dizzle's Avatar
The transfer case takes a little more than 2 quarts of ATF+4 transmission fluid. The rear 11.5 diff. will take 122 oz. or 3.8 quarts and the front 9.25 will take 76 oz. or 2.375 quarts. I use Redline 75w/90 and Mobil Delvac as well, so I cannot comment on the Amsoil product.
Two more fluids that are oftentimes overlooked until problems arise are the power steering fluid and brake fluid. I recommend you consider performing a flush of these systems as well. I use Valvoline ATF+4 in the power steering system and ATE TYP 200 or Castrol SRF brake fluid with stainless steel Speedbleeders to make the procedure simple.
Old Apr 7, 2013 | 12:11 AM
sallyman1's Avatar
Thanks
Old Apr 7, 2013 | 12:54 AM
C Schomer's Avatar
The series 2000 75w90 was really talked up when it came out and I tried it in my 97 d80 and it did very poorly. I hope the severe gear is better. Craig
13
Feb 16, 2012 09:48 PM
bluebull
Apr 21, 2005 07:32 PM
Don Shearer
Sep 16, 2004 03:12 PM
tarpilot
Sep 27, 2003 04:46 PM
bdog
Dec 18, 2002 05:55 PM
