Fluid capacities
Administrator/Jarhead
Fluid capacities
Mornin, DTR... I went to change out my transfer case fluid... no numbers inside the owners manual... it also says to use ATF-4... I thought that the transfer case was gear oil?
Also, dodge did not put fluid levels for the rear diffs and tranny... I did my tranny the other day, and it took two and a half gallons. ( aftermarket deep pan)
Soo... I need to know the transfer case and both diff's, please!
Thanks, DTR...
Thanks, DTR...
Definately use (I suggest Amsoil) ATF+4
Using anything other than ATF+4 will cause your 4WD to pop out of gear when throttle is applied, or you may not even be able to engage 4WD.
Trust me, I know from prior experience..........
Mark, both the transfer case and Hydroboost system use ATF+4, AAMs use your favorite gear oil.
Here are the capacities from the FSM:
9.25 AAM - 76 oz
NV5600 - 9.5 pts
G56 - 12 pts
NV271/273 - 4 pts
11.5 AAM - 122 oz
9.25 AAM - 76 oz
NV5600 - 9.5 pts
G56 - 12 pts
NV271/273 - 4 pts
11.5 AAM - 122 oz
bluebull
Apr 21, 2005 07:32 PM
Don Shearer
Sep 16, 2004 03:12 PM
