Finally 3.42 ring pinion installed
I have 285/75/17 Toyos on my 2WD and they do well. I like them better than my previous 285/70 BFGs. The pics in my gallery have the BFGs and I have pics of the Toyos here
http://good-times.webshots.com/album/561008331IFZyGV
MikeyB
The effect of 315s has a lot to do with where you are on the rpm/mileage curve at your typical road speed. Tests have the Cummins optimum mileage at 1750 rpm, but its pretty flat till about 2100 rpm where it drops off steeply. For 05-06 G56 trucks and 410s, 65 mph is on this steep slope, so doing anything to reduce the rpm has significant effect on mileage, even with a bit more rolling resistance. The mileage increase is usualy 7-15%. However, you can go faster with 315s at the same rpm, so many drive 70mph instead of 65 and that additional road speed eats into the mileage gains. So you will hear mileage numbers all over the place. Although I didn't go with the larger diameter tires for mileage, I drive 5 mph faster with the 315s and get a 10% fully corrected mpg boost.
Looks like 3.42's and a G56 is a little better than a NV5600 and 3.73's is... I run
1938 @ 65
2087 @ 70
2236 @ 75
When I got to 285/70's this weekend it will read
1876 @ 65
2020 @ 70
2165 @ 75
So far I dont mind the 3.73's with the NV5600 .73 6th, in fact when towing about 65mph I wish I had 4.10's or the .79 6th the G56 has.... I guess a GV would fix that
1938 @ 65
2087 @ 70
2236 @ 75
1876 @ 65
2020 @ 70
2165 @ 75
Any body ever consider running the 235 80 17 tires? that seems to be slightly larger diameter than the stock 265's and smaller width for hopefully, better mpg as well as winter traction.
Anyone?
Anyone?
Not enough to make a difference - 31.8" vs. 31.6". This is less than a 1% differance.
Texaschevelle
Oct 7, 2007 10:08 AM
pwabbott
54
Dec 5, 2002 08:26 PM
