Fast Idle
Old Sep 17, 2007 | 05:45 PM
dart4forte's Avatar
Fast Idle
Anyone have the code for the fast idle on the 2007 5.9?
Old Sep 17, 2007 | 08:18 PM
wreedCTD's Avatar
what do you mean code?
Old Sep 17, 2007 | 09:17 PM
NickBeek's Avatar
Yup, it's called your dealers Star Scan tool. The dealer must turn it on, unless you buy a programmer that has that function. Bully Dog has it , and Smarty has it too.
Old Sep 17, 2007 | 09:20 PM
scootertrash35's Avatar
is the fast idle engaged by the cruise like a big truck?does the dealer charge to do it?
Old Sep 17, 2007 | 10:39 PM
06Cummins's Avatar
yea it is engaged using cruise and accel/decell to go up and down between 1100 and 1500 rpm..some dealers will others wont..mine didnt
Old Sep 17, 2007 | 10:41 PM
wreedCTD's Avatar
mine is enabled via the smarty but i cant use accel/decel. when i hit set it goes to 1100 and stays there. am i doing something wrong?
Old Sep 20, 2007 | 04:20 PM
dart4forte's Avatar
Do you have a BD part number?
Old Sep 20, 2007 | 04:42 PM
Chessbay's Avatar
The cruise set button runs it up to 1100rpm's.
From there I can adjust in 100 RPM increments using the accel/decel button.
As long as it's in park and your foots off the brake it should work fine.
Old Sep 20, 2007 | 05:28 PM
ptgarcia's Avatar
It's just the Bully Dog Triple Dog.
Old Sep 20, 2007 | 05:38 PM
TonyB's Avatar
Actually, if you are careful, you can set it to any RPM between 1100 and 1500. Initially, I too thought it was only in 100 rpm increments.
Tony
Old Sep 20, 2007 | 06:30 PM
Fisherguy's Avatar
The BDTD newest software also has a PTO function that will take the revs up higher.
Old Sep 20, 2007 | 08:18 PM
Rescue516's Avatar
if its a standard shift need to ground that pin on the ECM too......
Old Sep 20, 2007 | 09:34 PM
kelley15's Avatar
The Triple dog pto function will take care of a 6 speed. No grinding necessary.
Old Sep 21, 2007 | 12:16 AM
Fisherguy's Avatar
You may be right, I think grounding the pin was to get the high idle to work...
Jim Lane
Dec 7, 2015 09:16 PM
EdmontonCanada
37
Dec 9, 2009 03:18 AM
trik396
Mar 14, 2007 07:57 AM
Pat-3500
17
Dec 3, 2002 06:13 PM
