Fast Idle on an 07
if your truck is an auto do this to see if it has already been enabled. start your truck, leave it in either park or neutral with the e-brake on. turn your cruise control on, press set. it should idle up to 1100 rpm or so. if this doesnt work i think this is the tsb, Cold weather idle TSB 18-004-04
My trucks (07, 5.9, auto) idle increases on its own after about 8-10 mins of idle time when I first start it up.
Do you folks run air compressors and such is that the reason for activating the fast idle feature?
If it's really cold mine will idle @ 1000rpm right after it starts until I press the brake, then the rpm will slowly drop down to 750. Semi-cold the high idle kicks in after a bit of idling.
EdmontonCanada
37
Dec 9, 2009 03:18 AM
