FASS or Air Dog
Old Apr 9, 2008 | 10:24 AM
53 willys's Avatar
my vote goes to the Airdog...It's Smaller, quieter and I can help you with ANY install questions you got too
size comparison...
even if this is a 200GPH FASS it still 10x bigger then a Airdog...and if the motor is the only difference...witch I was not even looking at...it's the hight and width of the FASS that is big....
Old Apr 9, 2008 | 10:29 AM
03RAMBUNCTIOUS's Avatar
I watch wind blow...
i like my FASS. its on there now. it does whine but you gotta pay to play... just like my noisy clutch.
Old Apr 9, 2008 | 10:30 AM
53 willys's Avatar
Originally Posted by bluechrome
You are incorrect I turned 505 uncorrected with a smarty and a 64/13 STOCK LP. Fuel pressure went down to 2psi. Look at the motor difference in the photos that mark posted. The fass is a 200gph @ 50psi which utilizes a much larger motor. Filters can be replaced with Fleetgaurds Filters.
I know some guys have put up some pretty good dyno numbers on stock lift pumps.(John_P)...but when I had my stock fuel system and smarty on SW#5 I could suck my FP down to 0psi in a heart beat on a run up the freeway on ramp!!
I would not be comfortable sucking my FP down to 2 psi or 0psi but thats just me.
Old Apr 9, 2008 | 11:08 AM
Diesel-Dan's Avatar
Again...the 95 Series FASS is pretty close to the same size as the AD.
Ask John-P.....he has a 200 GPH 95 Series FASS on his 12 Valve.......
Old Apr 9, 2008 | 11:11 AM
garbri's Avatar
Okay, total newbie question here.
Where do these mount, and what do you do with the stock unit?
garrett
Old Apr 9, 2008 | 11:12 AM
John_P's Avatar
Dan is right, I am running the big FASS on my 96' Dodge CTD 12 valve and it has worked great for me.
John_P
Old Apr 9, 2008 | 11:25 AM
53 willys's Avatar
your right that is smaller then the FASS150 version...but the pic I posted was of a AD150....so the comparison is fair
AD150 150gph next to a FASS150 200gph
if thats the case and the motors are the only difference then the AD150 is still a lot smaller then a FASS 150.
Old Apr 9, 2008 | 11:27 AM
53 willys's Avatar
garrett
the FASS with filters mounts in the rear drivers wheel well...the airdog mounts on the inside of the frame rail.
both good mounting spots IMHO
trailinone
16
Jun 19, 2009 04:28 PM
herb
Jul 18, 2008 08:25 AM
rmrc
Feb 13, 2005 05:25 PM
hialtitude
Oct 27, 2004 08:46 PM
AK RAM
19
Jul 28, 2004 04:54 PM
