fan shakes the whole truck?
Old Apr 15, 2008 | 12:54 PM
paroxysym's Avatar
ive noticed when my fan kicks on in my truck when im sitting at idle at a light or something it shakes the whole truck. makes a thud noise too- its never done that before. i have 72k on my truck. am i just now noticing it or is this normal and im making a issue out of it?
Old Apr 15, 2008 | 01:32 PM
rich's Avatar
i've heard that they do come apart havent had it happen to me but some have on the site
Old Apr 15, 2008 | 01:41 PM
06RAM2500's Avatar
Broken fan blade or bearing is going.
Old Apr 15, 2008 | 01:47 PM
paroxysym's Avatar
how can i check the bearing in the fan? none of the blades SHOULD be broke..
Old Apr 15, 2008 | 01:52 PM
dozer12216's Avatar
Things happen! Have you even looked at it yet? If blades are bent/broken, I suggest replace all components of fan. They do come apart and go through radiator. Bearing test is move blade fore and aft for excess movement. 3/8 inch movement is probablly too much.
Old Apr 15, 2008 | 02:33 PM
ZachMI2003's Avatar
When my fan is running at an idle I can see that it has some play from front to back. It seems that bearings might be the cause of my issue as well. I have not attempted to estimate the total range of motion it makes. I was about to post a thread about my issues. I'll have to look into it more thoroughly. Only 50,000 miles seems funny that the bearings would be bad already.
Old Apr 15, 2008 | 06:43 PM
Spooler's Avatar
When running your fan may wobble a little when disengaged. It's normal. Turn the truck off and grab a blade with your hand. If a bearing is going there will be a noticable loosness.
Old Apr 15, 2008 | 06:52 PM
paroxysym's Avatar
there is no play if you wiggle it back and forth.... i take it the fan should spin freely when the truck is off?
Old Apr 15, 2008 | 07:47 PM
Spooler's Avatar
Acutally No, it dosen't spin real free, if it does the fan clutch is bad.
Edited: If you spin the fan it should not make one revolution.
Timberman
13
Aug 7, 2006 11:43 AM
big jimmy
Jul 7, 2006 01:33 PM
IntakeRacing
May 25, 2006 10:39 PM
Hoss
20
Dec 8, 2004 09:40 AM
bwat4
Feb 8, 2004 09:10 PM
