Fan clutch
Old Aug 9, 2011 | 06:50 PM
rebal's Avatar
Exclamation Fan clutch
OK this is out of the norm ,but why is the wires for the fanclutch getting cought in the fan this is #3 and I cant aford this I have tripple checked this and it looks good after the install and its drives for a few weeks then WHAM! ripped up wires. any one have an idea?? please
Old Aug 9, 2011 | 07:02 PM
maxwellp's Avatar
Wires on your fan clutch? What year is it?
Old Aug 9, 2011 | 07:26 PM
louddodge's Avatar
I had the same problem with my 2003 and found out after 5 sets of wires that the radiator was not in the bottom mounts
Old Aug 9, 2011 | 07:30 PM
rebal's Avatar
its an 05 3500, radiator is in the mounts it seems to be bad hwy roads but theres got to be a fix. can the clutch be pinned? and how?
Old Aug 9, 2011 | 08:31 PM
maxwellp's Avatar
Talking
ok I just looked at my 05 and I have no wires to the fan clutch????
Just has a Viscous Fan Drive
Old Aug 9, 2011 | 10:08 PM
BigIron70's Avatar
Cummins Guru
I had the same problem with a truck from another dealership. They replaced the fan clutch three times for this problem. You need to check for runout in the fan hub. I replaced the bearing and hub and solved the problem. If you have any wobble in the fan and pulley then replace the hub and bearing. This causes the wiring to start whipping at higher RPM's. When that happens it catches the fan blade and rips out the wiring to the clutch. The other dealership also replaced the radiator because of damage twice. Good Luck
Old Aug 9, 2011 | 10:39 PM
Spooler's Avatar
Yes you do, you just don't know where to look.
Old Aug 10, 2011 | 12:25 AM
rebal's Avatar
Thanks I will check the runout tomorrow
Old Aug 10, 2011 | 07:42 AM
maxwellp's Avatar
Talking
Spooler - give me a hint. Does a 03 have this too?
Old Aug 10, 2011 | 10:06 AM
gcssr's Avatar
i'm not spooler, but yes your 03 does
Old Aug 10, 2011 | 11:17 AM
no_6_oh_no's Avatar
If you don't they already got ripped off at some time and your fan is only running at about 60% efficiency with the viscous drive.
Look on the bottm right hand side (facing front of truck) of the shroud. You should have a plug and metal tube bolted to the shoroud mount. The metal tube runs up the front of the rad to protect the wires. If the tube is not there and solidly mounted to the shroud mount the wires will never hold in front of the fan.
Old Aug 10, 2011 | 06:50 PM
rebal's Avatar
Well I think bigiron70 got it i watched the fan and it turns pefect but if I pull real hard I can get it to tilt a 1/2" in and out .gona change the bearing and clutch tomorrow an see..Everyone cross your fingers please
FamilyDiesel
Mar 30, 2008 05:53 AM
jrs_dodge_diesel
Sep 28, 2007 11:38 AM
MmmDieselFumes
Sep 27, 2007 06:44 PM
MmmDieselFumes
Sep 27, 2007 03:04 PM
big jimmy
Jul 7, 2006 01:33 PM
