fan blades??
Old Apr 12, 2005 | 05:04 PM
pullin hard's Avatar
fan blades??
i just changed my belt, and noticed that one of the fan blades has a slight crack in it. as i was trying to get the belt between 2 pulleys, i must have bent the fan blade with the crack some.
after install, i noticed a vib, through the brake pedal,which is on and off.when moving, more then idle rpm, it doesn't seem to do the vib.
when i got home , i looked at the fan , and noticed that i had bumped it apart, so i used needle nose pliers and put the blade back together. i figured this was causing the fan to not run true and balanced. but i still feel this vib through the brake pedal, some times through the skinny pedal too.
i can also hear this vib, and it get louder or more noticable when i engage the clutch fan.
i am trying to order a new fan blade replacement(won't mention any names here)
but i also heard that there have been some problems with the clutch as well.
anybody have or heard of this problem , or some thing similar????
it didn't do this before the belt change, and i can believe it would be the belt, or could it???
the belt was tight to get between the crank pulley and the big idler pulley above it, is there some thing there in that area that i could have bumped???/
any input would be of some help
thanks
Old Apr 12, 2005 | 09:17 PM
bubba33's Avatar
I would get that off there as soon as you can.I put a fan blade through the hood of my firebird.And it do not look perty sticking through the hood.
Old Apr 12, 2005 | 09:39 PM
Hemi Cat's Avatar
Definitely change the fan out asap. When blades break while running, they can go any direction and do a lot of damage, even hurt someone.
Old Apr 13, 2005 | 11:04 AM
Maccandy's Avatar
If it were me, I would NOT even start the engine again until I had the new fan on. But that's just me.
Old Apr 13, 2005 | 12:26 PM
Texcowboy9's Avatar
Many years ago when in the Air Force I knew a guy that had his bicep severed by a fan blade coming off. I WOULD NOT run the engine with a broken fan blade.
Old Apr 14, 2005 | 04:57 AM
man it's gonna be a long walk to work, over 60 miles one way!!!
tonystruck
Oct 26, 2007 11:02 AM
Shrimp
Sep 20, 2007 09:16 PM
big jimmy
Jul 7, 2006 01:33 PM
converteddzlr
15
Feb 9, 2003 07:09 PM
Jonesey
Jan 20, 2003 11:04 PM
