Extended cranking, running on 5 cyl
Old Mar 24, 2009 | 12:25 AM
nickg's Avatar
Looking for some help, I usually haunt the 2nd gen forums, I did some searching already and found that there is a wire that chafes thru near the AC compressor, no joy there as I did not find any issues with the wiring, I've spent a couple hours searching, and I'd like to have confirmed that a bad injector will cause extended cranking prior to starting. I'm working on my buddys 04, and about 8-9months ago I installed new nozzels (edge 80hp). I believe it has a bad injector as the #6 cyl is cold, you can put your hand on the exhaust port and its cold while the others are hot. engine takes forever to start and miss is more noticable at idle but you can feel it when under load (not as bad as it is at idle).
is there any easy way to confirm it? when they go bad do they return all the fuel back to the tank? If this is the case it would explain the extended cranking time as it has to build up rail pressure.
can anyone give me the cliff notes (overview)on the CR system??
Thanks
Old Mar 24, 2009 | 08:25 AM
rich's Avatar
all the ijectors that i have had allowed the fuel to bleed off causing an extended cranking. should be some info here on how to do a flow test on them
mbourland
Apr 5, 2007 09:05 PM
GR40RCapri
16
Jan 18, 2007 02:07 PM
honda_guy4
14
Apr 20, 2006 07:38 AM
slowmo
Apr 19, 2005 07:48 PM
Krazypapa
Dec 19, 2003 09:22 PM
