Erratic Oil Pressure
Old Jun 14, 2006 | 09:54 AM
Ian's Avatar
Ian
Howdy,
well, I've got a question about my '03 dodge. I've noticed that my oil pressure gauge is all over the map. AFAIK the actual numbers on the guage are different up here than yours, so I'll be as generic as I can.
When I start it up, it sits at about a 3/4-11/16 position (assuming far left is 0 and far right is 1, and dead center is 1/2) but it also falls down to nearly 1/4, or just a hair above the redline. When accelerating, it steadily increases from 1/4 to about 7/16, and when the accelerator is released, it falls back to 1/4. No codes have been thrown. If my oil pressure was steadily lower, I would assume an injector problem or something like that, but its all over the place. Anyone have any ideas??
Edit** Bad sending unit??
Old Jun 14, 2006 | 10:11 AM
P.J's Avatar
P.J
Gauge issue, 99 out of 100 times.
Old Jun 14, 2006 | 10:09 PM
Ian's Avatar
Ian
dandy...how would you go about fixin one of them? just leave it?
Old Jun 15, 2006 | 12:15 AM
no_6_oh_no's Avatar
If it is like the newer 3rd gen's its a cluster controller and not just a gauge. You don't want to know the cost unless you still "got warranty".
Put a manual gauage in for piece of mind.
Old Jun 15, 2006 | 06:17 AM
P.J's Avatar
P.J
If it were me I would rather see it work properly. Now then , do I know how to fix it ? ...No.
Check HERE
I would start with the pressure sensor first.
Old Jun 15, 2006 | 07:34 PM
nickleinonen's Avatar
there is no oil pressure sensor on our engines. there is a 6psi oil pressure switch. anything over 6 psi and the ecm controls the movement of the gauge in the cluster according to what the coolent temp is, the air temp is, the engine speed... it calculates what the approx. oil pressure should be and shows that...
Originally Posted by factory service manual
Engine Oil Pressure Message - The instrument cluster circuitry restricts the oil pressure gauge needle operation
in order to provide readings that are consistent with customer expectations. For all models except
SRT10, each time the cluster receives a message from the PCM or ECM indicating the engine oil pressure is
above about 41 kPa (6 psi) the cluster holds the gauge needle at a point near the middle increment within the
normal range on the gauge scale. For SRT10 models, each time the cluster receives a message from the
PCM indicating the engine oil pressure is above about 41 kPa (6 psi) the cluster moves the gauge needle in
a linear fashion to the proper relative pressure position of the gauge scale.
rebel_horseman
Oct 11, 2010 08:47 PM
firehawk
Jul 4, 2007 02:43 PM
stevesmitty
Mar 15, 2005 07:18 PM
TXJosh
Apr 28, 2003 08:43 PM
