Engine malfunction light-How do I cancel it?
Old Feb 4, 2007 | 07:21 AM
Darrell's Avatar
Hello, this is my first post. I hate to start out by asking advice.
Yesterday it was around -8 farenheit here. I was on my way to work and remembered my wife fueled up the truck the day before. I thought "Ohh crap she didnt put anything in the fuel so I pulled over on the highway and added a quart of the red bottle of diesel service. I think its called 911. I thought it would mix in good by the time I made it to work. No I would not normally use this stuff but I work 12 hour shifts and it was pretty cold out and its all I had.
When I got to work my rear tail lights would not go off. The head lights went out but the rear lights were on. I fiddled around with the fuses pulling whatever I could to get the lights out. Finially I figured out it was my trailer brake controller, so I unplugged it. I replaced all the fuses and went into work.
After my shift she started great(plugged in all day), but the engine malfunction light was on and stayed on. I think this may be due to pulling the fuses or the motor doesnt like the red 911 bottle.
******Is there any way to reset this dummy light?*****
2004.5 3/4 ton, no mods, auto trans, 3.73gears, 4X4, 4door, short box
Old Feb 4, 2007 | 07:29 AM
MikeyB's Avatar
You can do the key trick (off/on three time) to bring up the error. Most likely it's the P0514 code, battery temperature performance/rationality. One of those doesn't hurt anything codes.
As for clearing the code it will go away after so many key starts. Removing the negative battery terminals for around 5 minutes will clear also. Or run by Autozone and have them clear it for you with a scanner.
MikeyB
Old Feb 4, 2007 | 07:34 AM
Darrell's Avatar
Sweet thanks for the help! Does the key trick cancel the code or just reveal it? Were would I read the code at?
Old Feb 4, 2007 | 07:41 AM
MikeyB's Avatar
No, it won't cancel it. The odo/trip meter display will show the error code.
MikeyB
Old Feb 4, 2007 | 08:42 AM
Darrell's Avatar
The code read P0480
Old Feb 4, 2007 | 08:50 AM
MikeyB's Avatar
Good page to bookmark.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Has to do with the cooling fan.
MikeyB
3006DIESEL
Nov 23, 2009 06:01 PM
skeeterboy
20
Aug 23, 2007 08:10 AM
Chazman
May 3, 2004 09:28 AM
KSmith
Jan 22, 2003 11:13 AM
