Engine light stays on in 03 CTD
Old Sep 20, 2003 | 06:10 PM
chrismez's Avatar
Got my EGT gaauge installed today. I touched a couple of wires together during instalation which caused fuse #3 to blow. I changed the fuse, made sure nothing is touching. EGT gauge works but my engine light stays on, WHY? Did I screw something up or did the fuse tripping cause that? Wierd ......Thanks
Old Sep 20, 2003 | 06:16 PM
DF5152's Avatar
Re:Engine light stays on in 03 CTD
check the codes?
Old Sep 20, 2003 | 06:18 PM
chrismez's Avatar
What codes????Sorry
Old Sep 20, 2003 | 06:23 PM
DF5152's Avatar
not sure how the 03's work yet but im sure one will chime in. cycle the key on and off 3 times then leave it in the on position it will eaither cycle the check engine light or it give the code where the odometer is
Old Sep 20, 2003 | 06:36 PM
chrismez's Avatar
Cycled the key three times but it still stays on and no code pops up on the dash....
Old Sep 20, 2003 | 06:41 PM
DF5152's Avatar
does the check ingine light flash?
Old Sep 20, 2003 | 06:42 PM
chrismez's Avatar
No it just stays on. Is there a way to reset it myself, or do I have to take it to the dealer?
Old Sep 20, 2003 | 08:07 PM
Crabjoe's Avatar
To clear, disconnect the battery for some time. Most people I know disconnect then run their headlights on to help the power drain faster.
Old Sep 20, 2003 | 11:47 PM
pwabbott's Avatar
Check the fuel cap to see it is on tight. See warning printed on the cap.
Also the light will go off if the truck has three successful start cycles without any malfunction.
Old Sep 21, 2003 | 03:47 AM
chrismez's Avatar
Thanks, I will try the battery disconnect. I drove it around tonight and it runs perfect, 22MPG on the FWY. I think it is a glitch from the fuse blowing out. I tried the 3 times starting it but the light remains on....
Old Sep 21, 2003 | 10:29 AM
Crabjoe's Avatar
It's more then 3 times before the code resets. I know because I had a code on my Jeep for an oxygen sensor and after I replaced it, the code still stayed for another week. I must have cycled the ignition 50 times during that week.
Old Sep 21, 2003 | 01:27 PM
DF5152's Avatar
[quote author=chrismez link=board=20;threadid=19897;start=0#msg187284 date=1064134051]
[/quote]
what axle ratio?
Old Sep 21, 2003 | 02:32 PM
chrismez's Avatar
3.73.....Edge EZ definately improves MPG at 68/MPH
Old Sep 21, 2003 | 04:38 PM
chrismez's Avatar
Disconnected the batteries and solved the problem. Thanks
wcbcruzer
Jul 27, 2021 07:27 PM
coadman
Jul 10, 2006 07:22 AM
tuff
Aug 11, 2003 07:04 PM
Bobcat
May 12, 2003 09:14 AM
shrtmntdiesel
May 8, 2003 01:10 PM
