Engine hours vs. mileage on odometer
Old May 5, 2010 | 03:26 AM
  #121
highmileage's Avatar
I purchased mine from a hotshotter and use it for delivery of test equipment on the East coast.I also have a military truck hobby/addiction.I would like to to 20K on the hrmeter.Mine runs great,but probably will do injectors before winter.Reading these posts about meltdowns ect makes me paranoid.My boss used it to do a quick run to town last week.He asked where I found a low mileage truck??He says 39K miles is low for an 04.I said you better look at the odo again.Thats 397,000,not 39,700! Previous owner said no injector cleaners,or fuel additives and only used Rotella.
Old May 5, 2010 | 06:10 AM
  #122
levigarrett76's Avatar
ever had the transmission rebuilt?
Old May 5, 2010 | 06:59 AM
  #123
etn550's Avatar
Originally Posted by AH64ID
Thats some idle time!
Agreed. I've only owned it a few months. Oil consumption is low to none so ok. I only idle to cool down then shut off.
Old May 5, 2010 | 02:06 PM
  #124
no,orig tranny.His records indicate filters and fluid.I wanted a flush and band adjust.Hired the flush and did band myself.Really made a big difference.Orig owner said that alternator is orig,and most are done by now and recommended a dealership replacement.I may come winter when I do injectors.It has had 1 axle joint,headlight sw and a lift pump.Lift was done as a preventive measure.Has had the maint items,brake pads ect.I pulled 8k today for a good pull.I think it really helps them.Something I do wonder about...he said never to pull even a camper in overdrive unless on flat road?What do you think? It has 3:73s.
Old May 5, 2010 | 02:13 PM
  #125
hmmm...picture too large..I will work on that one.It looks almost new inside and out.I looked at 50K mile 07s that werent as nice.I figured it must be a good one so I got it.Not disappointed.
Old May 5, 2010 | 06:05 PM
  #126
It took the place of my car also.
Old May 5, 2010 | 08:16 PM
  #127
very nice truckl!!
Old May 6, 2010 | 09:50 AM
  #128
jim in houston's Avatar
Just went an checked mine with 155,730 miles with 4,249 hours = 36.65 mph
Old May 6, 2010 | 10:42 AM
  #129
Shorts's Avatar
41,763mls @ 1250Hrs = 33.41mph
I also got this display: C 447, 5 125, i (or maybe a comma?) 283
Old May 6, 2010 | 04:51 PM
  #130
dieseloutlaw1's Avatar
Bought mine new in July 05, 111,000 miles, 4,795 hours= 23.1 miles per hour. I let it idle alot in the summer, I don't like to be hot!!!
Old May 6, 2010 | 11:24 PM
  #131
J-man's Avatar
32.6 mpg on mine. Probably higher than that in reality since it's had 35" tires for at least 60k mls w/o recalibrating the odo.
Old May 6, 2010 | 11:43 PM
  #132
Zeppe807's Avatar
Huh, I got something like that too as far as after display: C 447, 5 116, .281
I have 69,000 miles and 2,292hours = 30.1mph
Old May 8, 2010 | 04:45 AM
  #133
Raucabye's Avatar
128,442 mi./ 4623 hrs. =27.78 Had 120k on it when I bought it.
On the other hand I have a tractor with a 12 vavle in it that has in excess of 8000 hrs
Old May 9, 2010 | 03:48 PM
  #134
DodgeDiesel61's Avatar
150,500 miles and 3,2xx hours.
Old May 9, 2010 | 04:12 PM
  #135
I forgot to add one small issue I had with it.Had a leaking ex manifold gskt on #6.Pretty easy repair.Too bad I bought and installed a turbo,had the intercooler press checked before I saw soot.Probably still got off cheaper than if I went to a dealership.$350 for the used turbo and $20 for the pressure check
