engine compartment
Old Jun 23, 2007 | 08:53 AM
DrBoost's Avatar
engine compartment
just wondering if I am able to spray engine degreaser then hose it off or will I screw something up engine looking real dirty want to clean up any suggestions?
Old Jun 23, 2007 | 11:10 AM
Wv7o's Avatar
I would think you should be ok just don't directly spray any electronic components (tipm,ect)
Old Jun 23, 2007 | 11:13 AM
ripping r's Avatar
you should be fine. i take mine to the car wash all the time. just dont spray right on your electronics.
Old Jun 23, 2007 | 01:10 PM
Pop-Pop's Avatar
I would wash it as you've suggested and then spray everything heavily with Armorall. After that, just use a high pressure air hose to blow the dust off. Retreat it with Armorall yearly.
Old Jun 23, 2007 | 08:54 PM
OOPS's Avatar
I blow mine off with my pressure washer all the time with no problems.
Doesn't that attract dust and dirt? I run a lot of fire roads.
Old Jun 24, 2007 | 08:40 AM
Pop-Pop's Avatar
Doesn't that attract dust and dirt? I run a lot of fire roads.[/QUOTE]
Probably would attract dust but it would still blow off better than having nothing on it at all. When I use the term "Armorall", it is generic. Actually, I use comparable products that do not leave a sticky surface thus attracting less dust. Routine degreasing & power washing is, IMHO, not great for the engine compartment. I think the hoses, wires, gaskets & plastic components should have a protectant on them. High pressure air cleaning is much more kindly to the engine compartment IMHO.
Toto
Aug 22, 2006 09:37 AM
coontz0473
32
Aug 21, 2006 07:07 AM
tobyw
Aug 2, 2006 01:55 PM
MK4288
Jun 22, 2004 11:38 AM
