Best cleaner for engine compartment?
Old Aug 13, 2006 | 06:06 PM
coontz0473's Avatar
Just wondering what you guys use to clean everything under the hood? Noticed while changing the oil today the top side of everything under the hood could use some cleaning ...Lot of dirt road traveling....I know they make some engine cleaner, but I want to make sure the cleaner won't harm any electrical connections ...Any suggestions would be appreciated...Thanks
Old Aug 13, 2006 | 06:17 PM
Turbobob's Avatar
I have always had good luck with Simple Green, full strength, in a spray bottle
Old Aug 13, 2006 | 06:20 PM
jpfishmaster's Avatar
I buy some of the purple junk from Lowes. Works well on engine compartment, frame, suspension, etc.
Old Aug 13, 2006 | 06:29 PM
Hounddog's Avatar
I tried GREEN and ORANGE etc.I like Gumout FOAMY ENGINE BRITE the best.Found the OTHERS discolored and left streaks,stains.Worked ok but not as good as the stuff designed to clean ENGINE areas.
Old Aug 13, 2006 | 06:50 PM
packard8's Avatar
One caution on the "purple stuff". If you mean Castrol Purple, it is HIGHLY caustic and will discolor and dull aluminum parts
(ask me how I know....lol).
I like the Costco house brand of simple green full strength. Spray it on and let it sit a few minutes, rinse it with fresh water at moderate pressure and then blow everything off with compressed air. I try to avoid spraying directly on any electrical connections.
Old Aug 13, 2006 | 07:00 PM
coontz0473's Avatar
Thanks Packard...I had some simple green I use to clean the tires when washing, but was afraid to use it until I asked the *EXPERTS*...Thanks again to everyone for the advice.
Old Aug 14, 2006 | 12:30 AM
Wulfdiesel's Avatar
lol, u guys are awesome
I wouldnever have even considered cleaning under the hood unless I just read this post
:adds simple green to shopping list:
Old Aug 14, 2006 | 05:12 AM
Kampnnut's Avatar
After it is nice and clean, spray it down with Armor All to help protect the rubber and plastic parts. Makes it look good too.
Old Aug 14, 2006 | 06:57 AM
Hounddog's Avatar
Well ARMOUR ALL has a bad habit of holding crud,creeping into elect.connectors and causing issues.Ruins door, window,cruise control,light switches AND DASH's .(holds heat,will about burn your skin off in direct sunlight)I find it to be nasty stuff.if you want a SHINEY engine bay spray it with a film of CLEAR laqure spray paint.Helps seal,looks great,causes no issues and lasts with out attracting dirt,dust and makes it easier to clean in the future.
Old Aug 14, 2006 | 07:19 AM
MikeyB's Avatar
Simple Green or Fabuloso. Both will make the engine compartment smell good.
MikeyB
Old Aug 14, 2006 | 10:09 AM
angleiron's Avatar
Simple green took the paint off the valve cover on my last truck...so either it was too strong or the paint was poorly attached?
Old Aug 14, 2006 | 11:09 AM
Bluedeviltorque's Avatar
I have been using the stuff called Orange Blast. Seems to work ok and doesn't eat the driveway like gunk and some of the others.
I don't know how well it will work on really soiled motors though. The way I usually clean my engine compartment is, car wash soap and water, sponges (small and big), and a few towels. Then I try to dry it off so I don't leave water spots.
Yes, i'm rather nuts, but you can work under my hood and rinse your hands with just water and they'll be clean.
Mike
Old Aug 14, 2006 | 11:46 AM
MikeyB's Avatar
I can take the paint off by rubbing my finger on it.
MikeyB
Old Aug 14, 2006 | 03:33 PM
hemi5oh's Avatar
Thumbs up Believe it or not
I've had great luck with lysol kitchen and bathroom cleaner. I used to detail my mustang constantly, and this stuff works.
Old Aug 14, 2006 | 04:08 PM
jon05ctd's Avatar
I use a detail spray for the painted surfaces.
Rubber protectant for the rubber and vinyl
Everything else just gets wiped down with a damp old bath towel dipped in auto shampoo. Then rince with another damp towel and dry.
