Engine Cleaning
Old Jan 21, 2006 | 03:20 PM
PurNLoud's Avatar
Engine Cleaning
Just wanted to ask what yall use to clean the motor off. All I have is dish soap and figured there must be somthing that works really well. Thanks for yalls input.
Old Jan 21, 2006 | 03:33 PM
CIN'S DODGE's Avatar
Mrs. missin on a mission & keeper of the can
Well there are a couple things you can use.Simple Green, Mean Green, Really any type of degreaser will work but I have always used these two.
Old Jan 21, 2006 | 03:37 PM
PurNLoud's Avatar
Alright, thanks, had to ask b/c of the electronic componets and what they will take and what they won't
Old Jan 21, 2006 | 03:58 PM
kens_isb's Avatar
i use half simple green and half water but that's with my 02 camaro, but i guess with an iron block you can use striaght simple green with no problems.
Old Jan 21, 2006 | 04:00 PM
On the bottle of Simple Green your suppose to dilute it.
Old Jan 21, 2006 | 07:25 PM
PurNLoud's Avatar
simple green straight??? that will eat concrete, 4 oz. s.g with 28 oz. water is stongest I have ever mixed it after seeing what a spill did to my driveway
Old Jan 21, 2006 | 09:01 PM
dodgetech77's Avatar
I just did mine today and used purple power straight.spray on and spray off
Old Jan 21, 2006 | 09:14 PM
RDM16CTD's Avatar
I wash the engine & compartment every 2 or 3 months. Park it the night before where I want to wash, so it's overnight cold before I start. Cover electrical boxes and air filter with plastic grocery bags, wet the engine with a light spray, mist it with Simple Green, and wash with a brush while misting with more water. Done this with all my cars for years, and never have to degrease because they never get really dirty if I keep up with it. Never had any problems this way
Be sure to remove plastic grocery bags when done!
Old Jan 22, 2006 | 08:36 AM
slimpicken's Avatar
Castrol Engine degreaser in the purple bottle works great. used it on a truck that was covered in crude oil from years in the oilfield and it took the stuff right off. Word to the wise however, WEAR GLOVES when using this stuff cause it ate my hands up. Took over a mmonth for all the skin to finally quit peeling and heal . I got that gallon jug at walmart but that has been a year ago and still on the same bottle. It works
Old Jan 22, 2006 | 03:10 PM
kens_isb's Avatar
it's an iron block, don't worry about it. If it was aluminum then you'd have to worry about it.
Old Jan 22, 2006 | 03:15 PM
bigblock2stroke's Avatar
Foamy Engine brite spray
EverydayDiesel
19
Aug 2, 2007 05:36 PM
MK4288
Jun 22, 2004 11:38 AM
LinearX
19
Jan 16, 2004 04:22 AM
lezmark7
Jun 27, 2003 10:01 PM
ET RAM
Feb 24, 2003 07:49 PM
