engine clattering in idle
Old Jun 24, 2007 | 12:28 PM
panhandle girl's Avatar
engine clattering & tries to die in idle
Hi,
I'm new @ this, so bear with me. I have an 04 6 speed HO quad cab dually with 49k miles on it. The other day after a 4 hr trip pulling a 4H trailer w/1 horse & driving w/the cruise set at 75 on the interstate, when I pulled up to a stop light it started making a horrible clattering noise & the mil light came on & stayed on. The pickup was in nuetral when it started this as I was setting still. It kept trying to die & did it again when I pulled into the fairgrounds in OKC. I made to the stalls & shut if off & it's never done it again.
I have an auxillary fuel tank, but I had been driving on the same fuel since I had left home the day before & I went home on the same fuel & it has never done it again. It's going to the dealer for service tomorrow but I was wondering if anyone has had the same problem.
Thanks in advance
Old Jun 24, 2007 | 01:01 PM
jrussell's Avatar
Check to see if your oil level is over-filled. Could be a bad injector?
Old Jun 24, 2007 | 01:10 PM
Rpainter's Avatar
could be the fca going bad or maybe the rail sensor? any codes
Old Jun 24, 2007 | 04:37 PM
bdewey's Avatar
Is the light still on. Check for codes by turning your key on and off 3 times with out starting truck to get codes.
Old Jun 24, 2007 | 05:30 PM
The light isn't on anymore. Codes are P2127, P0652,P0341. I bought it new & this is the first trouble I've had with it.
Old Jun 24, 2007 | 05:40 PM
PolishAggie's Avatar
Mine did the same thing few weeks ago (I didn't notice the mil light). I had pulled heavy couple of days before it happened which I dont normally do. My buddy (a gas mechanic) said pulling helps clean the injectors & some carbon may have loosened up & I probably heard it working itself through. I am new to this but it sounded feasible.
danalex
Nov 6, 2010 10:37 PM
bigcat83
Feb 15, 2010 01:44 PM
kennyhammond
Oct 20, 2009 08:17 PM
Txwelder
Jan 22, 2006 12:46 PM
steelsoldiers
21
Dec 19, 2002 04:08 PM
