Engine changes RPM at idle
Old Oct 18, 2007 | 02:38 AM
josh brown's Avatar
When stopped in traffic my truck (06 auto) changes rpm, you can hear it change tone as it sounds the rpm is lowering but the tach doesn't move it stays right at 750. It has been doing this for a while and before any mods. I noticed my friends PSD does a similar thing. Is this normal? Driving my truck is flawless. I am fairly new to diesel and am used to a gasser keeping one exhaust tone while idling. Thanks
Old Oct 18, 2007 | 04:35 AM
jrussell's Avatar
You sure it's not from the A/C clutch engaging and disengaging?
Old Oct 18, 2007 | 09:50 AM
53 willys's Avatar
A/c cycling or Grid heaters??
Old Oct 20, 2007 | 02:15 PM
josh brown's Avatar
Could it do it if my ac is not running? If so that could be it, from the outside I hear a slight click when it happens.
Old Oct 20, 2007 | 04:18 PM
realsquash's Avatar
Do run some kind of pressure box?
Andy
Old Oct 20, 2007 | 04:39 PM
vzdude's Avatar
DTR's 'Go to Guy'
Remember, the a/c compressor works while in defrost mode as well.
Old Oct 20, 2007 | 08:52 PM
Jeff in TD's Avatar
Does it only do it during cold outside temps?
If so, I'd bet it's grid heaters.
Old Oct 20, 2007 | 08:59 PM
caper11's Avatar
100 bucks says your a/c compressor is cycling, every vehicule with a/c does this, you'll also notice a power loss on smaller hp engines.
Hope this helps some
Old Oct 21, 2007 | 08:59 AM
josh brown's Avatar
No pressure box and like I said it did it stock. Maybe it is just the A/c it does it warm and cold, maybe a little more when cold.
Old Oct 21, 2007 | 10:20 AM
vzdude's Avatar
DTR's 'Go to Guy'
Do you run the defrost? A/C shouldn't be on unless in a/c mode or defrost ( any position between floor and defrost runs it too)
Old Oct 21, 2007 | 07:11 PM
53 willys's Avatar
Also, if at the same time you hear the "click" you also see the voltage gauge drop then you know it is the grid heaters.defrost-a/cgrid heaters it's gotta be one or the other.....
jefjsak
Jan 15, 2015 03:44 PM
Steven ziegler
Oct 30, 2014 05:12 PM
MWomack
Mar 16, 2007 11:49 AM
salyera
Feb 8, 2006 07:37 AM
fishin fever
Feb 22, 2004 08:32 PM
