Engine blew up on way home need help
Old Sep 30, 2009 | 09:27 PM
RVPro's Avatar
Unhappy Engine blew up on way home need help
Engine came apart and windowed both sides of the block and destroyed the starter. What year blocks will work with my cylinder head? Also how heavy is the motor?
Old Sep 30, 2009 | 09:29 PM
annabelle's Avatar
I don't know about the heads, but to engine weighs about 1000 lbs.
Old Sep 30, 2009 | 09:31 PM
Purplezr2's Avatar
I believe the head is about 200 I believe engine is like 1100 dressed out.
Old Sep 30, 2009 | 09:32 PM
no_6_oh_no's Avatar
Any 3rd gen block should work but the pistons are different in the 03-04 engines. You would need an 04.5-07.5 short block to match the electronics and injectors in the truck.
Old Sep 30, 2009 | 09:44 PM
rich's Avatar
i got an 03 block short block that needs some honing and has been sitting out in the weather for about 1.5 years . if not i got a guy here who should have some low mileage cr motors
Old Oct 1, 2009 | 08:28 AM
rogers259's Avatar
Sorry to hear that, what the heck happened?
Old Oct 1, 2009 | 09:25 AM
CamperAndy's Avatar
Yea, you need to post details on carnage like that.
Old Oct 1, 2009 | 09:51 AM
BPoulsen's Avatar
Pics too!!!
Old Oct 1, 2009 | 09:54 AM
psd1's Avatar
339898 miles engine blown/ trans untouched ...thats alot of miles. I think you got your moneys worth!
Old Oct 1, 2009 | 06:19 PM
trik396's Avatar
I want to know what would window BOTH sides of the block...? Talk about catastrophic engine failure....
Old Oct 1, 2009 | 06:25 PM
homewrecker's Avatar
What the heck is with these 05's?I have 2 friends who have windowed the block and read of several others.
Old Oct 1, 2009 | 06:26 PM
tonyd01's Avatar
what oil filter you run?
Old Oct 1, 2009 | 06:34 PM
96_12V's Avatar
Pictures? And details?
I know with that sort of mileage you must be busy - and you're using your diesel truck. However we're a curious lot, and catastrophic failures pike the intrest. Must not have sounded very good...
Old Oct 2, 2009 | 01:04 AM
RVPro's Avatar
I will get some pics and hopefully start swaping it out this weekend. Unfortunatly there is not a good story to go with this carnage. I left work made my normal uturn under 75 got on the gas to get around a slow moving BMW and then boom, knock, knock, knock glanced down at the guages still had oil pressure. Hell it was still running. Saw the check engine light come on and killed it. Coasted into Huffines Kia. I was kind of hoping theflex plate had broken or the input shaft of the trans. Alof those dreams were dashed when I saw the trail of oil and herd the oil pouring out on to the ground. I have blown lots of motors in my life but I have never had one go like this. In the past I have allways seen the oil pressure drop just before something lets go.
Old Oct 2, 2009 | 02:39 AM
TexasCTD's Avatar
Kurt, did you have any success finding a replacement motor?
Was the motor still cold when you got on it? What kind of oil filter? Any ideas on why this happened?
So sorry to hear this, but it is VERY unusual for one of our motors to blow like this unless extremely modified and perhaps a shot of nitrous. Yours is still stock or basically stock IIRC.
