which engine in 04'?????
Old May 13, 2006 | 05:26 PM
Dusty Ratcliff's Avatar
is there a different # or letter in the vin # on an 04' truck to tell which engine it has???? I'm looking at an 04' 3500 crew cab dually & was wondering if it was the 600 or 610 motor, I was thinking that they switched in 04.5???? thanks in advance, Dusty
Old May 13, 2006 | 05:29 PM
PourinDiesel's Avatar
Dusty,
The engines have a white label on the top drivers side that says how much HP they have.
If it is a 325hp then it is a 2004.5 600.
If it is a 305hp then it is a 2004 555 tq engine.
Old May 13, 2006 | 05:35 PM
thanks, i'm looking at the truck over the net, it's about 6 hr's away & they don't have any pictures of the engine at all, so i was hoping the vin might help, but I don't think after doing some more reading that it's gonna give me the info I need???? guess I'll have to call back & see if they can check for me, thanks a bunch, Dusty
Old May 13, 2006 | 08:19 PM
12PACK's Avatar
Both the 555 and 600, as well as the 05 610's have a "C" in the 8th spot. The SO has a 6.
The build date on the door jamb will help, too.
Old May 13, 2006 | 09:06 PM
mikmaze's Avatar
just a chance that someone here might be a lot closer than 6 hours away nand willing to check it out for ya, where is the one you are looking at?
Old May 13, 2006 | 10:04 PM
Guardrail's Avatar
This might help you.
Old May 13, 2006 | 10:27 PM
the truck is in Columbia Tn, just a bit south of Nashville, it's an 04' crew cab 6sp. Laramie, & they claim it has a 2 spd. rear, i'm thinking gear vendors or u.s. gear????? here's a link .... http://www.autotrader.com/fyc/vdp.js...en&cardist=310
anybody seen or know the truck??????? thanks again, Dusty
Old May 14, 2006 | 07:28 AM
DCross's Avatar
My 2004.5 3500 QC 4x4 Laramie 6 sp loaded was only $33,000 new. Check with Woodhouse Dodge in Blair NE. They will deliver you a new one cheaper than you can buy used. Just my opinion.
Bradleysram
19
May 12, 2009 08:36 AM
moTthediesel
Nov 18, 2004 11:00 PM
rmb93243
Jul 9, 2004 12:51 AM
mcevins
Dec 2, 2003 11:38 AM
atc250r
May 12, 2003 02:56 PM
